Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This post was updated on Nov 15, 2015; 7:03pm.
It has been 8 months since 2.0.7, and LibreCAD v2 has become better.Exciting New Features: 1. DWG read support! Big thanks to our CAD expert Rallaz ; 2. SVG export support! Salute to dinkel ; 3. Arabic Language GUI support. More work is needed for: * Right-to-left support for Text entities; * Arabic fonts for Text. 4. More user configurable settings in App Preferences. Under the hood, there's lots of cleanup and coding style tweaking towards C++11, and the code base should be cleaner for new developers. There is also lots of GUI and user experience tweaking, mostly following user requests. Clearly, LibreCAD needs help from more developers with the large volume of feature requests and bug reports from our user community. The LibreCAD Team Download installers: https://sourceforge.net/projects/librecad/files/?source=navbar https://github.com/LibreCAD/LibreCAD/releases commit log since 2.0.7 is following: Armin Stebich (29): added language support for arabic Merge pull request #472 from serval2412/master applied patch #473 from glixx, added GenericName to librecad.desktop for KDE systems refactoring of construction layer attribute Merge pull request #475 from serval2412/master fixed errors from pull request #475 Merge pull request #485 from leogargu/482-add-area-circle added/updated icons for File Export/Import/Save/Save As, Current Drawing Preferences and Help Manual; removed broken librecad16.png modified Draw Line icons as requested in forum, left to right direction adjusted column width of layer list, because of cropped icons Ellipse: snap on foci too when snap on center is activated clean up requestImageOpenDialog() and set All Image Files as default garbage deleted in latest SVG icon files added new image and tool tip for mouse widget in status bar added snap endpoints and middlepoints for full circle quadrants fixed RS_Circle::getNearestMiddle() comment for better doxygen formatting fixed drawing preferences, dimension alignment change needs dim text update too fixed RS_EntityContainer::getNearestCenter(), issue with multiple recursion fixed github issue #504, uninitialised values in RS_VariableDict Merge pull request #509 from korhadris/master fixed typo in errormessage, rs_filterdxfrw.cpp revert -j to -j4 for mingw32-make in windows build, build server crashed fixed gitgub issue #527, tool tip for selection toolbar forward button fixed polyline vertex dragging, as reported on IRC fixed dimension refpoint dragging fixed spline point dragging fix: apply status bar font size to active layer widget Merge pull request #541 from Solvoj/master centralized default graphic colors in RS_Settings Christian Luginbühl (8): Extracting XML writing to dedicated class, added interface and rewrote to use QXmlStreamWriter Added (hopefully really needed) include of QObject Fixed 'File -> Export' icon Added unclosed degree 3 splines for convertion to bezier curves Added closed degree 3 splines for convertion to bezier curves Added quadratic splines for convertion to bezier curves Passing a few variables by const(ant) reference to omit copying stuff Fixed regression of ellipse creation in MakerCamSVG arising from f123224 Dongxu Li (366): bug#493, default dxfrw filter for dxf files build-osx: default gcc by MacPorts as in wiki build-osx: updated building scripts bug#497, allow saving by modified view printpreview: fixed offset message added Amiri fonts c++11 coding style splinepoints: fixed a crash, typo printing: fixed custom paper size arcTangential: use MuParser for options tan3: relaxed tolerance tan3: fixed a degenerate case layerwidget: context menu it text tan3: more fixes to find all possible solutions layerwidget: allow shrinking by expanding drawing area polyline: update bounding box after modification, bug#504 command line focus: show by shortcuts bug#499: try only existing recent files bug#504, more fixes for invalid recent files File cleanup tan2r: find all solutions tan2r: fixed createTan2 Merge pull request #502 from yoc3/master inscribe ellipse: degenerence troubleshooting ellipse: inscribed in symmetric trapezoid image: do not select image by rect for draft mode ellipse inscribed: fixed a crash vector methods use c++ vector instead of QVector header cleanup more header cleanup header cleanup rs_arc.h header cleanup rs_ellipse.h header cleanup math.h RS_VectorSolution: range based loop rs_arc: fixed some compiler warning more compiler warning fixed snapper file cleanup ellipse inscribed: using intersections to form quadrilateral ellipse inscribe: file cleanup added comment more header cleanup, initializer list header cleanup ellipse inscribed: file cleanup ellipse inscribed: more file cleanup rs_vector: cleanup for get() method, bug#508 form quadrilateral: file cleanup command line: added default event filter from mdiArea file cleanup widget size policy: bug#503 Merge pull request #507 from korhadris/master Merge pull request #508 from Ngassa/master rs_creation: header cleanup blockinsert: header cleanup actions: default dtors RS_Modification: QList -> std::vector clone() to const method hyperbola: cleanup entitycontainer: cleanup data classes to struct type spline data cleanup layerwidget: fixed a layout warning layerwidget: minor coding style math const: M_PI_2 for half Pi file cleanup bug#513: fixed draw mtext crash file cleanup RS_Vector: initializer list ctor vector solutions: initializer list style file cleanup infoarea: file cleanup Merge pull request #510 from Ngassa/master math: minor cleanup more file cleanup muparser: folder structure muParser: updated bundled to svn r34 version fixed a spline crash, bug# 514 spline: more vector usage vectorsolution cleanup ellipse: simplified from quadratic Force color mode for PDF exporting updated appdata.xml vector: simplified toInteger added llge dxf library: issue #506 llge data scripts ellipse: cleanup for fromQuadratic() infodist: precision by unit settings InfoAngle: precision by unit settings InfoDist2: precision by unit settings more info: precision by unit settings merged dinkel's SVG saving TODO: win32 building needs libxml2++ Squashed commit of the following: README cleanup drawText: fixed a crash drawText: fixed a crash updated README.md rs_vector: fixed a crash ellipse: fromQuadratic cleanup inscribed ellipse: fixed a tolerance issue ellipse: create from quadratic form replaced QVector with std::vector mdiWindow: file cleanup mdiwindow: file cleanup Squashed commit of the following: new CAD toolbars commit 2641731a5f8357290b1689d065e5992898069db3 Author: Dongxu Li <dli@tamaggo.com> Date: Sat Apr 18 13:51:46 2015 -0400 moved LC_SimpleTests for testing fixed a compiler warning file cleanup renamed MakderSVG additions to LC_ prefix drw_entities: fixed a compiler warning snap toolbar cleanup file cleanup ellipse: fixed foci ellipse: more file cleanup snap toolbar cleanup camSVG: static to anonymous camSVG: use ellipse::getEllipsePoint() Merge pull request #518 from dinkel/fix-qobject-include drawingOptions: landscape cleanup issue #716, by Palmitoxico more issue #716 fixes file cleanup recent files: cleanup recentFiles: moved some methods from appWindow file cleanup snap command fixes moved GUI for tests to LC_SimpleTests cadtoolbar: adjustsize() when displaying toolbar SplinePoints: fixed crash by ref points issues #520 fixed last commit fixed a crash by freehand line, bug#515 line freehand: cleanup file cleanup dxfrw: register class deprecated rtti() const member function rs_entity: file cleanup rs_entity: refpoints constness rs_entity: getGraphic constness rs_entity: more constness fixes getNearestDist: constness getNearestCenter: constness count(): constness entityContainer: range based loop header cleanup: math entitycontainer: more range based loop grid: file cleanup grid: file cleanup grid: file cleanup grid: file cleanup grid: file cleanup grid: file cleanup grid: removed grid count() methods grid: limit parameters grid: file cleanup rs_pattern: file cleanup constructionline: file cleanup rs_graphic: c++11 style polyline: equidist option sizepolicy graphicview: fixed a segfault at closing graphicview: file cleanup rs_graphicview: constness cleanup graphicview: more constness const_cast cleanup cadtoolbar: fixed restoreAction defaultAction: show previous cadtoolbar at right click plotequation: fixed for bundled muparser muparser: building cleanup circle2pr: cleanup circle2pr: draw circle center in preview circle2pr: cleanup fontList: c++11 style mouse tip cleanup file_io: c++11 style file_io: detectFormat for both read/write file_io: cleanup file_io: file cleanup cli calculator: precision=12 rs_layer: constness cadtoolbar line: fixed parallel through equation solver: run newton-raphson building scripts: auto jobs for make snapToolBar: show restrict orthogonal in snap ToolBar equation solvers: added debugging info bisector: GUI improvement file cleanup osx building: make -j4 by default, building server issue osx: qmake uses default spec header fixes: <cmath> Revert "osx: qmake uses default spec" inscribed ellipse: highlight the last line circle inscribed: highlighten tweaking inscribed circle: verify solutions circle inscribed: gui tweaking ellipse inscribed: gui atomicentity: separate into cpp orthTan: preview cleanup highlight: redraw changed entities file cleanup osx: building qmake spec file cleanup tangent2: show highlighted circles tangent2: avoid catching the same circle twice creation: file cleanup orthTan: line start/end point fixes tangent1: highlight arcs file cleanup file cleanup issues #525 : shift key clears command line header cleanup header cleanup file cleanup units: file cleanup units: update units: cleanup fractional format General option: modify layer attribute of selected at layer activation General option: Modify layer of selected, text file cleanup settings: file cleanup file cleanup tan2_1p: fixed a crash at Esc, issues #478 math: file cleanup change layer for selected: added to undo cycle linetype: cleanup undocycle: file cleanup grid: file cleanup undo: file cleanup Fixed a spline crash: issues #529 More fixes for issues #529 draw spline: cleanup arc:file cleanup issues: #528 #530 cleanup for layer deletion blocklist: new algorithm for newName() at copying container: count selected by entity types Experimental: skip "Select" action, if already selected fontList: cleanup fixed a print preview crash fixed a print preview crash fileio: building issues tan3: find all tangential circles for 3 lines file cleanup file cleanup container: use std::set instead of QList splinepoints: removed QList blocksmove: replaced QList with std::vector line/polyline: QList to vector tan3: fixed for a pair of parallel lines actions: constness tan3: fixed 1/2 lines tan3: file cleanup container: fixed std::set building issue for fBSD quadratic(e,e): fixed line counting quadratic: fixed tangential circle of two circles tan2, tan3p: file cleanup actions: removed leftover updateToolBar() quadratic: cleanup for private members toolbar select: message cleanup ellipse fociPoint: help message parallel through: file cleanup printpreview: cleanup print preview/default: action cleanup parallel through: cleanup highlight at finish printpreview: fixed menu entry logic mdiWindow: fixed a crash at closing debug: debugging macro tweaking action: rtti() cleanup action modify: header cleanup file cleanup draw actions: qaction cleanup cpp header style dim entities: constness constness cleanup tangential2: fixed ellipse/ellipse issues #497 : fixed tan3 for line and 2 circles issues #497 : fixed tan3 for 2 line2 and 1 circle issues #490 fixed moving by focus for ellipse ratio larger than 1 hatch: a fix for ellipse detection hatch: a fix for hatching regression file cleanup plugin list: added splinepoints type fixed a polyline regression fixed a hatching regression Drop Event to open files eventhandler: file cleanup RS_Entity: copy ctor, experimental feature actions: file cleanup infoangle: file cleanup lock relative zero: file cleanup bevel: file cleanup snapper: catch by a set of entity types catch entities by a set of entity types vector: initializer_list cleanup command: switch from QHash to std::map command: added more full commands command: file cleanup command: file cleanup command: cleanup of QObject leftover vector: file cleanup command: updated command definitions document: fixed copy ctor, bug# 521 entitycontainer: added copy ctor container: fixed previous commit Revert "container: fixed previous commit" Revert "entitycontainer: added copy ctor" Revert "document: fixed copy ctor, bug# 521" Revert "RS_Entity: copy ctor, experimental feature" optionsDrawing: fixed an qt4 building issue command history: hide/show context menu command history: fixed a typo hatch: fixed a regression at copy/move file cleanup scripts: added nightly-build-osx.sh plotequation: file cleanup plotequation: generate splinepoints, POC plugin: added addPolyline() api cadtoolbar: removed base cad toolbar form plot equation: added options for entity types cadtoolbar: minimum width=73 cadtoolbar: file cleanup plugin api: fixed a building issue on fBSD Revert "cadtoolbar: file cleanup" waiting for rework on CAD toolbars Revert "cadtoolbar: minimum width=73" SVGMaker: initial support for more length units makercamsvg: constness fixes makercamsvg: minor tweaking of units splinepoints: file cleanup cadtoolbar: toolbar sizes cadtoolbar: file cleanup optiongeneral: fixed a building issue splinepoints: added bounding rect method for a segment Merge pull request #544 from rvt/master splinepoints: spline/spline intersection by checking segment overlap splinepoints: a quick fix for snap-middle, could break splinepoint snap-middle splinepoints: fixed snap-middle draw line hor/ver: show snap point math: file cleanup math: quadratic solver, numerical stability gui: PoC for device pixel ratio freehand line: show snapper by mouse move freehand: file cleanup tan3: added support for point entities tan3: file cleanup entitycontainer: allow snapping on blocks, bug#523 graphicview: ctor style cleanup default action: allow panning by Ctl- dragging tan3: updated tooltip build-osx.sh: allow using of system default qmake nightly-build-osx: fixed previous commit bug#494: added command for lengthen command: more details on alias file zoomIn: file cleanup issue #546 , Ctl +/- to zoom around cursor graphicview: file cleanup freehand: fixed preview at drawing time preview: fixed the previous commit painter: constness overlay: experimental: bit xor to avoid invisible preview splinepoints: fix for qt4/clang painter: header cleanup graphicview: draftmode cleanup graphicview: file cleanup fBSD: qt4 building issue bug #526 redraw updated relative zero file clenaup bug# 509: avoid default pdf file name in dialog 2.0.8 preparation issue: #554 scroll bar slider sizes issue #554 : fixed slider sizes Julien Nabet (2): Fix cppcheck warnings: - (style) Same expression on both sides of '||' - (performance) Prefer prefix ++/-- operators for non-primitive types cppcheck: memory leaks Leonor's Penguintosh (1): Add full circle area function Miguel E. Hernández Cuervo (1): libdxfrw: Removed unnecessary return statement from "lineWidth2dxfInt(enum lineWidth lw)". Ngassa Amalia (1): Corrected a comment in drawwllipseaxis.h Pootle (6): Updated translations from pootle server Merge branch 'master' of https://github.com/LibreCAD/LibreCAD Updated translations after lupdate Updated translations from pootle server Merge branch 'master' of https://github.com/LibreCAD/LibreCAD Updated translations after lupdate R. van Twisk (1): Modified build scripts for OSX Rallaz (39): libdxfrw: added support for AppId libdxfrw: mem leak in dtor. libdxfrw: added support to extended data libdxfrw: support to write ext data added use of extended data for contruction layer libdxfrw update to 0.6.0 make filterdxfrw working & enable dwg support added missing files from previous commit libdxfrw: dwg, bugs & image support update messages in filterdfxrw fix overloaded warning & os/x error add hack to pass fit point as control point libdxfrw: fix some memory issues libdxfrw: fix issues & complete header write update to 0.6.1 fix mem leak Patch for bad check font format rewrite RS_FilterDXFRW::toNativeString to solve complex tags WIP: add more options for dimensions, lw ready added fixed length in linear dims dim units ui ready dims: units & precision ready dims: color support ready dim: added support for text style & decimal separator corrected DIMTXTSTY -> DIMTXSTY Merge branch 'master' of github.com:LibreCAD/LibreCAD fixed minor typo in libdxfrw plugins: fix SF bug #470 enable build of picfile plugin list plugin, correct print of color prevent crash with round/bevel in text Fix bug #449 & crash whit polyline bevel when no trim Merge branch 'master' of github.com:LibreCAD/LibreCAD correct previous commit Bug #225 Always draw dim text in solid line plugin:addPolyline() arc support verify correct ratio in ellipse don't read/write empty polylines Revert "don't read/write empty polylines" correct don't read/write empty polylines Tamas TEVESZ (4): Update FreeBSD instructions Update FreeBSD instructions Fix README.md Suppress error message amalia (1): Some hacks to the formulars to convert between radians,degrees and gradians dinkel (3): Merge pull request #536 from dinkel/fix-export-icon Merge pull request #538 from dinkel/feature-makercamsvg-splines Merge pull request #539 from dinkel/fix-makercam-ellipse korhadris (3): Fixing issue:500. Setting the checkbox for the Statusbar option in the View menu to be checked to reflect that the status bar is displayed by default. Merge pull request #1 from LibreCAD/master Modifying QC_ApplicationWindow::loadPlugins to skip loading plugins with the same file name. This is a common problem when using two versions of LibreCAD (one installed and one in a build area). r-a-v-a-s (8): implemented QColorDialog and added more default colors added default custom color; added current value as initial color added layer/block selection color option added link to wiki Germans like long words, not long links. set help manual links to open in web browser shortened wiki link set object name to fix saveState error ravas (32): added more commands added 11 commands fixed bevel/fillet merge; fillet has cmd now added commands for 8 more actions added commands hatch, ha, mtxt, txt changed selection highlighting in command output added missing bracket remove whitespace from start and end of command input automatically copy commandline output selection unified command input/output selection color cal: convert sin(45d) to sin(45*pi/180) improved previous commit removed testing remnant simplification / improvement of last commit switched to QRegExp for now promoted teHistory promote teHistory (part 2) simplified and organized remember tab in drawing preferences remember tab in application preferences removed unused functions updated comments changed layer selection color removed font size 14 for statusbar paler green until option is implemented fixed grid hotkey Merge pull request #542 from r-a-v-a-s/color_options Merge pull request #545 from r-a-v-a-s/selection_color Merge pull request #547 from r-a-v-a-s/wiki_link fixed sc/sd command bug hide print preview options; issue #552 added some links // clean up yoc3 (1): fixed issue #498: Tiny line styles aren't saved |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
