| Loading... |
| Reply to author |
| Edit post |
| Move post |
| Delete this post |
| Delete this post and replies |
| Change post date |
| Print post |
| Permalink |
| Raw mail |
Happy new year! LibreCAD 2.0.9 released
This is mostly a bug fixing release. Fixed a few crashes due to undo and deleted entities; Rallaz fixed quite many issues in dxf and DWG support. If you are using spline/splinepoints, you may find some improvement in 2.0.9, as spline mirroring is fixed, and there is some cleanup for spline property editors, thanks to jaise for identifying this bug. If you use the feature "Draw -> Line -> Rectangle", please note a polyline is drawn instead of 4 separate lines. There are lots of fixes on hatching issues as well: most notably, hatch preview works again! Various polyline issues are also fixed: bevel/fillet, equidistant, and some minor cleanup. Jerry worked on several issues with command auto-completion and supported commands. There are lots of language support improvements: fonts and translation. Thanks a lot to our friends! Commits since 2.0.8: Armin Stebich (3): added debug/ wildcard to .gitignore for clean Windows repos another fix for commit: rs.h headers 78471946 ignore Windows generated files in libdxfrw Dongxu Li (84): rs_graphicview: header cleanup fixed incorrect rvalue reference usage more ravlue reference fixes SCMVERSION=2.0.9 issue #479 : wheel events be handled by scrollbars zoomscroll: file cleanup getIntersection: reverted to ArcArc intersections #484 file cleanup undocycle: use std::set to avoid duplicated entities, #557 issue #557 : fixed a crash due to undo cycles rs_command: file cleanup rs_command: detect string collision of commands rs_debug: singleton mode file saving: only update autosaving filename with success vector: c++11 style cleanup issue #579 , fixed incorrect command hints during Action command: file cleanup vector: fixed a regression dim: fixed snapper for diameter/radius/angular snapper: constness Accumulated fixes from master branch Squashed commit of the following: iso3098 azomix fonts by AZO avoid highlight flag in offset fixed a crash by undo bug 531: bounding box checks for intersection dimension: compiler warning rectangular area: initial port of rectangular areas from V3 rs_line: fixed bounding box checking in getIntersection lc_rect: allow zero size rects construction line: fixed regression on drawing vectorsolutions: fixed find closest on subset drawline: fixed "undo/redo" commands undo: file cleanup undo: stop all suspended actions to avoid crash by deleted entities eventhandler: file cleanup lc_rect: 'using' instead of typedef grid: replaced QRectF with LC_Rect painter: header cleanup snaptoolbar: fixed a segfault at closing rs.h removed Qt headers fixes and cleanup for commit: rs.h headers 78471946 A minor binary search optimization Squashed commit of the following: vector/quadratic: explicit conversion to boolean header cleanup: use <iosfwd> file cleanup fixed building issues for commit f3a4e847c another header fix for commit f3a4e847c trim amount: improved length input handling issue #617 removed snap indicator hatch: fixed a hatch drawing issue. Revert "hatch: fixed a hatch drawing issue." hatch: fixed a preview regression hatch: preview rectangle loop cleanup splinepoints: file cleanup bug545: spline properties dialog cleanup splinepoints: initial property dialog spline points: file cleanup spline points: control points in property editor spline points: file cleanup spline points: fixed a qt4 building issue exit dialog: header cleanup bug 544: spline mirror entity container: header cleanup avoid potential performance regression by 527cbd40 spline properties: dialog style bug517: equidistant polylines file cleanup bug548: invisible layer, exporting as image pentoolbar: use devicePixelRatio file cleanup building issue for qt4-mac, header issues printpreview: added commands: blackwhite/color undoable: c++11 style undo: cleanup arc: move by center rs_arc: override identifier read coustom.pri as well as .pro bug552: fixed a construction layer regression AZO: font fixes polyline: cleanup polyline: cleanup polyline: experimental, create from selected entities bug549: dxfrw: troubleshooting an infinite loop Jerry (1): Fixed conflict in rs_commands.cpp Jerry Magnin (2): Added command shortcut for dimension angular Adding new commands for dimensions LordOfBikes (1): Updated translations from pootle server, after lupdate Pootle (3): Updated translations from pootle server Merge branch '2.0' of https://github.com/LibreCAD/LibreCAD into 2.0 Updated translations after lupdate Rallaz (14): dxfrw: use radians in drw_insert entity dwfrw: parses shadow handle dxfrw: fix in dwg hatch dxfrw: fix in dwg 2004 pages Enable draw of 4 corner solids sf bug #527 correct default DIMDEC & DIMADEC Dims, more work with zeros completed decimal dimzin support libdxfrw: update to 0.6.3 more dims compatibility libdxfrw: write dimfxl in dim styles SF bug #535 correct bevel with polylines SF bug #539 Vertical dimension's alignment Fix dim horizontal alignment Rupicapra-rupicapra (1): Added help tip, shortcut command & corrected bug ravas (1): removed experimental composition mode; issue #576 |
| Loading... |
| Reply to author |
| Edit post |
| Move post |
| Delete this post |
| Change post date |
| Print post |
| Permalink |
| Raw mail |
OS X users can try the app I just uploaded:
https://sourceforge.net/projects/librecad/files/OSX/2.0.9/ This actually contains more bug fixes than noted above. https://github.com/LibreCAD/LibreCAD/commits/2.0 Let me know if it does or does not work for you! |
| Loading... |
| Reply to author |
| Edit post |
| Move post |
| Delete this post |
| Change post date |
| Print post |
| Permalink |
| Raw mail |
great! do you get a script to do building and uploading?
| Loading... |
| Reply to author |
| Edit post |
| Move post |
| Delete this post |
| Change post date |
| Print post |
| Permalink |
| Raw mail |
I built it in Qt Creator,
created the dmg with macdeployqt, and then used hdiutil for bzip2 compression, which basically cuts the size in half! I have not attempted to write a script yet. |
| Loading... |
| Reply to author |
| Edit post |
| Move post |
| Delete this post |
| Change post date |
| Print post |
| Permalink |
| Raw mail |
