About hatch
About hatch
Dima
Can do whatever the hatch was tied closed area? So when you change the geometry of a closed area, and changed the shading.
I'm use current version of LibreCAD installed from ppa:librecad-dev/librecad-daily
Sytem xubuntu 16.04
Re: About hatch
Christian
I am not totally sure I understand your question well, but...
If you hatch a closed area and then alter the shape of that area, the hatch will not change. You will have to delete the hatch and hatch the new area again.
Christian
Re: About hatch
yes, you are correct. The current hatching algorithm is not dynamic. Changing the contour doesn't update the hatch, without going through the "Create Hatch" part again.
Lots of work is needed here.
Christian wrote
Christian
