Any click heisenbug segfault
9 messages Options
ManDay
When I run todays 81dbddf7c78921893bd3670b5c87771a2f62ec67 and I click on the canvas or anywhere on the tools I get a segfault. Doesn't happen in gdb, so no BT for you. I just thought I tell you before this becomes a week long bisect.
Re: Any click heisenbug segfault
the commit 81dbdd is a fix for segfault when clicking without dragging with tool drawLineFree, so it should not segfault when clicking only.
I suspect the heisenburg you are seeing is from debugging build, a problem already fixed by commit,
https://github.com/LibreCAD/LibreCAD/commit/fdf759b452428b91a0664121a2b98603c5553a22
I still need to know how to show the line when dragging.
Dongxu Li
On Fri, Aug 12, 2011 at 5:43 AM, ManDay [via LibreCAD] <ml-node+4692670-1698252502-233
[hidden email]>
http://librecad.1049103.n5.nabble.com/Any-click-heisenbug-segfault-tp4692670p4692670.html
ManDay
I bisected to
c9abbfae3efd79be22b359561e1452525f762d9a is the first bad commit
PS: That has nothing to do with dragging. It already segfaults upon mouse-down.
ManDay
And no, it happens with 23f8811359013e61788d17f4a6fe552c8308d5e0 too. It really is that "next command tip"
Please try with the master branch on my repository: https://github.com/dxli/LibreCAD
Or the equivalent patch attached.
If it still segfaults, please tell me in more details on how to reproduce it. Apparently, it doesn't crash here.
Thanks,
Dongxu Li
On Fri, Aug 12, 2011 at 8:07 AM, ManDay [via LibreCAD] <[hidden email]> wrote:
http://librecad.1049103.n5.nabble.com/Any-click-heisenbug-segfault-tp4692670p4693030.html
commandTip.patch (2K) Download Attachment
In reply to this post by ManDay
Update: a typo in previous patch, please use the master branch instead
<a href="https://github.com:LibreCAD/LibreCAD">https://github.com:LibreCAD/LibreCAD
ManDay
Hi Li,
no, doesn't happen with your repo.
ManDay
Something is pretty strange: I'm back on master of the official origin and remade
c8d94e6a5ea044bdb29c2ac0cfa998640b5a6d61
now I don't get the segfault any longer but the cursor is mal-drawn. It is basically without alpha. Any clue?
There's a fix for cursor over white background. I am not satisfied with it yet, but at least the cursor is visible over white background.
At least the segfault is fixed, which has a higher priority.
Thanks,
Dongxu Li
On Fri, Aug 12, 2011 at 11:02 AM, ManDay [via LibreCAD] <[hidden email]> wrote:
http://librecad.1049103.n5.nabble.com/Any-click-heisenbug-segfault-tp4692670p4693599.html
