[Block Menu] Insert Block Fails... help needed!
JamieVanCadsand
Hey LibreCAD Users...
I try to create one of more blocks for arch drawing... but if i insert my block,
the block don't want insert...
If i get created one or more blocks...
I click on the block menu... if i have one or more blocks creates...
than i click on 'insert block' and than i want to use my block (insert them) for my arch
drawing... i click on the left mouse button and my block don't insert them...
Its so thad i can't select my block thad i want to insert them... if i click everywere
on the block menu, i get the same menu...
Can anyone tell me the steps, incl. screenshots to let see how i can use blocks,
save blocks and insert them, please ?...
Thanks for help, Jamie.
Re: [Block Menu] Insert Block Fails... help needed!
To create block:
click on "create block"
select the entities and finish selection with "enter".
specify reference point
give block a name
activate the wanted block in the block list first and then click on "insert the active block", release mouse button.
when you move the mouse cursor to the drawing area, a preview bounding box appears.
at the desired place drop with left mouse click.
JamieVanCadsand
Thanks for help, my way is hopefull to copy the block and use it for as example
architectural designs...
Jamie.
