Blocks only partially appear
strikeeagleIII
I've been working on a drawing of my house and today when I opened the file noticed several of the block that had been inserted only showed up partially.  ly appear but mostly don't and in the living room the couch and the chair are missing elements.  If I open the dxf file for the block itself, it shows up normally as it should.
The file itself is here:https://www.dropbox.com/s/71d9j70p4k7ih0o/12McHugh_Current.dxf?dl=0
Any idea what's going on?
Re: Blocks only partially appear
Found the missing elements you have marked on the layer "contour", which was switched invisible.
strikeeagleIII
Awesome--not sure how they got mixed on different layers.  There was a weird combination where both layers had to be visible for the ones on the contour layer to show up. Thanks!
