Cannot open flie.
12 messages Options Options
Cannot open flie.
Jim Thompson
This post was updated on Feb 01, 2014; 9:47am.
I am unable to open the file of a previously worked on drawing. i get this notification:
"Cannot open the file
/home/jim/Desktop/##Wing planform.dxf
Please check the permissions."
Where do I "Check, the permissions" please?
edit: I found permissions in properties. I tried multiple settings options, all resulting in the same message as above.
Screen shot of my permissions window:
http://i.imgur.com/a9WAklO.png
Re: Cannot open flie.
sp1der
Hi Jim
Linux Mint - good choice :), I have this on my laptop.
Jim try ticking the 'execute' box and try again, although it seems strange to me why you should have to check permissions on the file.
Have you recently upgraded from 15 ?
Is this a file you have previously drawn with a different CAD program ?
Is this the only file this happens with ?
Try creating another test file and see whether you get the same result.
Jim Thompson
Yes I tried that, doesn't help.
Funny thing is, I can open some files and not others.??
sp1der
Hi Jim
Are you able to attach an example of a file that is not opening here on the forum for testing ?
Jim Thompson
Here is one of the files that will not open.
Plank_fuse_design.
Let's see if that works.
sp1der
Hi Jim, the file you have attached is in a text document format and not dxf? so I cannot open it either!
you can save it to a dxf file name.
It opens properly for me.
one thing I'm not convinced is your special characters in file name. can you rename to to regular file names and try again?
sp1der
It doesn't even download properly from the forum, how are you opening it ?
Re: Cannot open file.
Use the "Save source as..." function from your browser's context menu and add the extension .dxf to the file name in the save as window.
About opening files without .dxf extension please read bug report #441 on sf.net.
The message about permissions is misleading here, we have to refine this.
sp1der
Thanks for that, yes I can open it up fine now too.
Jim Thompson
I'm managing to save files and then open them again now. I'm still a bit confused, but fairly sure it was the way I was saving the initial file.
Now I open a new file, start the drawing and then try saving and opening to make sure before proceeding. Then it if opens, I know I can continue working on it.
Thanks to all.
