Changing the radius of the "fillet" command
Arkieking
When trying to "fillet" intersecting lines, the radius seems to be about 1/2".  Is there a way to reduce the radius? I need to round over the edges of a 1x2 and need about 1/8" radius.
Thanks,
Arkieking
Re: Changing the radius of the "fillet" command
When you select the fillet tool, somewhere on the top tool bars the tool options bar should appear. There you can change the fillet radius to your needs.
