Cleaning Up Drawings
electrosteam
I have a circle centre sitting in the middle of the drawing that does not appear to be associated with any arc in the drawing.
Probably a remnant of a construction sequence.
Ordinary deletion doesn't work.
I have identified which layer it is on.
I there any way of systematically cleaning a drawing of these sorts of anomalies ?
John
Re: Cleaning Up Drawings
I don't know of an automatic clean-up process.
What does "Properties" say? Maybe radius = 0? Linetype = No Pen?
Does "Select All" and "Auto Zoom" show the associated arc?
What kind of deletion does work?
Maybe you can delete everything else, so isolate that entity and save as an extra file. If you provide that file maybe someone finds out what's wrong.
electrosteam
Dellus,
Humble pie is my next meal.
Delete did get rid of the centre, but only if I selected the whole drawing on that layer.
You gave me the clue to find the arc, clicking on the centre for properties revealed a large radius, tiny arc lost in the clutter.
I will remember that hint,
Thanks,
John
PS
Along the way discovered that you can select an arc by clicking on its centre.
