Command line commands
j.burtner
Hi, New to LibreCAD here but long time CAD user for various drawing/drafting tasks.
This package is looking really great ! I am so excited to have found this. Thanks so much to the community.
I am wondering if there is a list of commands somewhere that the command line accepts...
For instance, I try to type zoom to open up the various zoom-tools but that doesn't do it. Maybe the commands are different or maybe I can dig around in the src repo and find a list somewhere if it works like that.
This is awesome! Thanks for the great package!
Cheers,
jb
ps. I am currently running with the most recent (RC1) windows release candidate on a vista system.
-j
Re: Command line commands
j.burtner
Found it in the source repo.. Awesome!
Here is a quick overview for anyone interested:
------------- SNIP -----------------
DRAW CMD:
"point" = DrawPoint
"po" = DrawPoint
"line" = DrawLine
"ln" = DrawLine
"l" = DrawLine
"polyline" = DrawPolyline
"offset" = DrawLineParallel
"o", "offset" = DrawLineParallel
"parallel" = DrawLineParallel
"par", "parallel" = DrawLineParallel
"arc" = DrawArc3P
"a" = DrawArc3P
"circle" = DrawCircle
"ci" = DrawCircle
"rectangle" = DrawLineRectangle
"rec" = DrawLineRectangle
"rectang" = DrawLineRectangle
"text" = DrawText
ZOOM CMD:
"regen" = ZoomRedraw
"rg", "zoom - redraw" = ZoomRedraw
"zr", "zoom - redraw" = ZoomRedraw
"zw", "zoom - window" = ZoomWindow
"za", "zoom - auto" = ZoomAuto
"zp", "zoom - pan" = ZoomPan
"zv", "zoom - previous" = ZoomPrevious
EDIT CMD:
"kill" = EditKillAllActions
"k" = EditKillAllActions
"undo" = EditUndo
"u", "undo" = EditUndo
"redo" = EditRedo
"r" = EditRedo
DIMENSION CMD:
"da", "dimension - aligned" = DimAligned
"da" = DimAligned
"dh", "dimension - horizontal" = DimLinearHor
"dh" = DimLinearHor
"dr", "dimension - linear" = DimLinear
"dr" = DimLinear
"dv", "dimension - vertical" = DimLinearVer
"dv" = DimLinearVer
"ld", "dimension - leader" = DimLeader
"ld" = DimLeader
TOOL CMD:
"dimregen" = ToolRegenerateDimensions
MODIFY CMD:
"tm", "modify - multi trim (extend)" = ModifyTrim2
"tm" = ModifyTrim2
"xt", "modify - trim (extend)" = ModifyTrim
"xt" = ModifyTrim
"rm", "modify - trim" = ModifyTrim
"rm" = ModifyTrim
"mv", "modify - move" = ModifyMove
"mv" = ModifyMove
"ch", "modify - bevel (chamfer)" = ModifyBevel
"ch" = ModifyBevel
"mi", "modify - mirror" = ModifyMirror
"mi" = ModifyMirror
"ro", "modify - rotate" = ModifyRotate
"ro" = ModifyRotate
"sz", "modify - scale" = ModifyMove
"sz" = ModifyMove
"ss", "modify - stretch" = ModifyStretch
"ss" = ModifyStretch
"er", "modify - delete (erase)" = ModifyDelete
"er" = ModifyDelete
"oo", "modify - undo (oops)" = EditUndo
"oo" = EditUndo
"uu", "modify - redo" = EditRedo
"uu" = EditRedo
"xp", "modify - explode" = BlocksExplode
"xp" = BlocksExplode
SNAP CMD:
"os", "snap - none" = SnapFree
"os" = SnapFree
"sg", "snap - grid" = SnapGrid
"sg" = SnapGrid
"se", "snap - end" = SnapEndpoint
"se" = SnapEndpoint
"si", "snap - intersection" = SnapIntersection
"si" = SnapIntersection
"sn", "snap - center" = SnapCenter
"sn" = SnapCenter
"sm", "snap - middle" = SnapMiddle
"sm" = SnapMiddle
"sn", "snap - nearest" = SnapMiddle
"sn" = SnapMiddle
"np", "snap - nearest point" = SnapOnEntity
"np" = SnapOnEntity
SELECTION CMD:
"tn", "Deselect all" = DeselectAll
"tn" = DeselectAll
B Basaj
In reply to this post by j.burtner
Hi, I'm new to LibreCAD as well.  I had used AutoCAD and IntelliCAD in the past.
I not having too much trouble finding commands via the menu, toolbars etc., but just how do you implement a command on a given selection?
e.g., I want to mirror two lines.  I select "mirror" toolbar button, and select the two lines (I've also tried reversing the order of these two operations).  Then what?  I right-click (as in ACAD or Intelli), nothing happens.  How do I tell it I'm done selecting?  How do I tell it what the mirror line is?
Same with moving or copying.  How do I tell it I'm done selecting objects, and ready to specify a place to move/copy to?
B Basaj
Aha! so that little green double-arrow button is the key to the next step.
Thanks!
Ray
Ray
Thanks for screencast, but doesn't seem to help me because you  are selecting objects (circles in your example).
What I want to do is select a group of lines, choose a mirror line and ..... Mirror. Can't fathom out why Librecad won't let me do what I used to do in Qcad.
Would appreciate some help on this.
Also, why is there no Delete Segment command in the Modify menu?
Regards,
Ray
