Compiling instruction
hsrai
On page http://librecad.org/cms/home/get-involved.html link for "Compiling Instruction" is missing.
H.S.Rai
H.S.Rai
Re: Compiling instruction
davinder
According to me the compiling instruction is here for librecad
http://librecad.org/cms/home/from-source/linux.html
But can anybody tell me, if i want to enable some extra features which are disabled from default but included in software, then what should be the command or instruction for that?
Thanks in advance.
2011/7/13 davinder [via LibreCAD]
<[hidden email]>:
> Thanks in advance.
If you want to activate the code between the tags
#ifdef RS_OPT_PYTHON
#endif
add in librecad.pro:
DEFINES += RS_OPT_PYTHON=1
INCLUDEPATH += pathToPithon/include
In reply to this post by davinder
David,
currently we don't have any feature that can be build by adding arguments to qmake or make.
We are (well Ralaz mostly is) on a plugin interface but that's not stable enough.
You can however, run the qmake and make magic in the plugins directory to build
the current supplied plugins for testing. However, this is not yet part of the general build.
Ries
Thanks in advance.
http://librecad.1049103.n5.nabble.com/Compiling-instruction-tp4569484p4581594.html
Rallaz,
have you been testing the python features within LibreCAD? Does that work?
Ries
<<a href="x-msg://1320/user/SendEmail.jtp?type=node&amp;node=4581778&amp;i=0" target="_top" rel="nofollow" link="external">[hidden email]>:
> Thanks in advance.
#endif
http://librecad.1049103.n5.nabble.com/Compiling-instruction-tp4569484p4581778.html
Only a small compile-test
The rs_python require a python<3.0 and fail to compile
as rs_python.h says :
 * Python scripting support.
 * OBSOLETE
For rs_simplepython adding in librecad.pro:
DEFINES += RS_OPT_SIMPLEPYTHON=1
INCLUDEPATH += /usr/include/python
LIBS += -L/usr/lib64/python/config -lpython2.6
It compile and link, but this is the most I've tried because only speak C/C++ and AutoLisp
