Convert pdf to dxf
Convert pdf to dxf
Rylos
I'm looking for a Freeware to convert pdf to dxf.
Do you know if I can find it?
Thank you for your answer
Rylos
Re: Convert pdf to dxf
rolgiati
On Tue, 2 Aug 2016 07:38:04 -0700 (MST)
Not a freeware, but have you considered www.pdftodxf.com/ ?
Cheers,
Ron.
                         The arrogance of officialdom
                      should be tempered and controlled,
                       and assistance to foreign hands
                     should be curtailed, lest Rome fall.
                       -- Marcus Tullius Cicero (attrib.)
In reply to this post by Rylos
An open-source solution is inkscape. It can open pdf and then save as dxf. But be prepared that there will be a lot of editing necessary. Text and dimensions will be shown as dumb lines only, also distances can always be a little bit off the real value. Pdf just is no cad compatible format.
humulus
Hi Rylos,
I've also been looking for this, but couldn't find I good freeware solution.
The PDF files we get can contain vector drawings or scanned drawings (or both), so I had to find a solution that supported vectorizing bitmap drawings.
The list of programs I've tried:
- Inkscape
- Aide pdf2dxf
- anydwg pdfdxf
- autodwg pdf2dwg
- cadsofttools abviewer
- coolutils totalpdftodxfconverter
- investintech able2extract
The only program I found that did what we wanted was PDF2DWG from AutoDWG, but it's $220,-
regards,
Ruud
