Crash on print
Crash on print
minisaurus
Hi all - I'm trying to print a 1:200 drawing to a pdf (Cute pdf) and LibreCAD takes ages and eventually get shuts down by Windows.
The print preview looks fine - I set the scale and centre the print on the paper, but when I hit print .... 10 minutes later Windows closes LibreCAD down.
I'm running 1.0.0rc1 on Windows XP. The file was a DWG converted to DXF using Any DXF to DWG converter.
I have the same problem when trying to print this in QCAD Professional
Can anyone help?
Re: Crash on print
This sounds like a problem in the PDF 'printer',
you can try this by printing on a normal a4 (if you have a printer) if this works,
then the PDF print must be handling 'something' incorrect.
Ries
Can anyone help?
http://librecad.1049103.n5.nabble.com/Crash-on-print-tp4782192p4782192.html
