Crash on save, crash on open??
7 messages Options
bunkem
Hi.
I downloaded 1.0 RC1 for the Mac and I am unable to save any files that I create.  I also can't open dxf files without a crash.  This is a repeatable issue.  I've tried in 32 and 64 bit mode.
Where can I submit a detailed report?
I'm running OSX 10.5.8.
In the mean time here is part of the report.
Process:         LibreCAD [21945]
Path:            /Applications/LibreCAD.app/Contents/MacOS/LibreCAD
Identifier:      com.yourcompany.LibreCAD
Version:         ??? (???)
Code Type:       X86 (Native)
Parent Process:  launchd [183]
Interval Since Last Report:          59734 sec
Crashes Since Last Report:           4
Per-App Interval Since Last Report:  776 sec
Per-App Crashes Since Last Report:   5
Date/Time:       2011-07-11 20:40:09.607 -0400
OS Version:      Mac OS X 10.5.8 (9L30)
Report Version:  6
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread:  0
Dyld Error Message:
  Symbol not found: __ZSt16__ostream_insertIcSt11char_traitsIcEERSt13basic_ostreamIT_T0_ES6_PKS3_i
  Referenced from: /Applications/LibreCAD.app/Contents/MacOS/LibreCAD
  Expected in: /usr/lib/libstdc++.6.dylib
Re: Crash on save, crash on open??
hey,
that's very odd... it's the first OSX report I get and I am even developing and testing on OSX!
I might already have enough with the message below, but if it's ok, I come back to it.
Ries
On Jul 11, 2011, at 7:45 PM, bunkem [via LibreCAD] wrote:
Hi.
Version:         ??? (???)
Report Version:  6
Crashed Thread:  0
Dyld Error Message:
http://librecad.1049103.n5.nabble.com/Crash-on-save-crash-on-open-tp4577192p4577192.html
Graham Klyne
In reply to this post by bunkem
I've been experiencing a similar problem: crashes when saving to DXF.  Also sometimes crashes while doing nothing - I've never had it running for more than about 15 minutes,
LibreCAD Version:
Version: 1.0.0rc2
SCM Revision: 1.0.0rc2
Compiled on: Aug 14 2011
Running on MacOS 10.5.8.
Terry
I'm having the same issue.  LibreCAD worked perfectly until I did the system update on 11.10 on 1/7/12.  Since then the program closes every time I try to open or save a drawing.  I'm using a Pavillion dv6000, 2gb mem, AMD 64 Athalon 2, Ubuntu 11.10 32 bit.  Hope this helps.  I really want to use this program.  I had loaded, edited and saved a complex drawing with 25 layers with no problem before doing the update.
Terry,
what version of LibreCAD are you using?
Ries
http://librecad.1049103.n5.nabble.com/Crash-on-save-crash-on-open-tp4577192p5135386.html
Terry
Version: 1.0.0rc1
SCM Revision:
Compiled on: Oct 4 2011
Portions (c) 2011 by R. van Twisk
please test with a newer version, or the newest from github.
thanks
On Sun, Jan 15, 2012 at 6:01 PM, Terry [via LibreCAD] <[hidden email]> wrote:
Version: 1.0.0rc1
SCM Revision:
http://librecad.1049103.n5.nabble.com/Crash-on-save-crash-on-open-tp4577192p5147373.html
Dongxu Li, Ph.D.
