Polyline is the name for the single entity, which is a succession of lines and arcs.
In detail, the polyline is a collection of vertices, which are connected straight (lines) or with a bulge (arcs).
A polyline with two vertices, connected straight, is equal in appearance to a line entity. But internally and in DXF representation they are different entities. The same is true for a polyline from two vertices connected with a buge and an arc.
For constructing I usually use lines and arcs, as there are more and better drawing options. But for machining it is better to have polylines as they are continuous contours without gaps by definition.
So after drawing and trimming the lines and arcs I create a polyline of them which could be easily processed by a CAM processor.
