Daily builds doesn't seem to update
7 messages Options
Broomy
I'm happily using the daily builds versions of LibreCAD from ppa:librecad-dev/librecad-daily , but since decembre the 18th it doesn't seem to update. Am I doing something wrong?
Thanks in advance,
Broomy
Re: Daily builds doesn't seem to update
Broomy
Maybe I'm the only one with this problem, but LibreCAD still doesn't seem to update.
This is what I've done:
sudo add-apt-repository ppa:librecad-dev/librecad-daily
sudo apt-get update
sudo apt-get upgrade
This is what LibreCAD reads in the "About" -tab:
Version: master
SCM Revision: 2.0.0rc3
Compiler: GNU GCC 4.6.3
Qt Version: 4.8.2
Compiled on: Dec 18 2013
I'm using Bodhi and kxstudio, both based on Ubuntu 12.04.
I spoke to Scott this morning,
and he was going to supply a fix. This seemed to happen with Ubuntu 12 that doesn’t
suport c++11.
it’s likely because of something in common.pri.
We both got buzy with work so I am not sure if it’s fixed now, can anybody test that on ubuntu 12?
On Apr 23, 2014, at 1:29 PM, dxli [via LibreCAD] <[hidden email]> wrote:
have a look at:
https://launchpad.net/~librecad-dev/+archive/librecad-daily/
http://forum.librecad.org/Daily-builds-doesn-t-seem-to-update-tp5709737p5709839.html
To start a new topic under Troubleshooting, email [hidden email]
for gcc-4.6 and lower, use:
g++ -std=c++0x
for gcc-4.7 and higher, use:
g++ -std=c++11
maqifrnswa
It's working now. Like dxli said, since ubuntu 12.04 uses an older gcc, those flags had to be set. It'll resume updating daily!
Broomy
Great,
Thanks guys!
