Jeg har med glæde opdaget og hentet dette flotte tegneprogram, som tilmed tilsyneladende fungerer udmærket med mit linux (ubuntu 14.04 LTS) operativsystem.
Men jeg støder ind imellem på slåfejl/stavefejl i den danske udgave. Hvor kan jeg indberette dem? Med venlig hilsen
Med venlig hilsen
Louis |
Thank you.
I just visited the site you mentioned and sent a mail to the administrator. I am looking forward to be hearing from him on what to do. Den 2014-04-25 14:11, R. van Twisk [via
LibreCAD] skrev:
Louis
Med venlig hilsen
Louis |
noolsen,
you should now have admin permission for Danish language. So you can accept your own and other users suggestions. Navigate to the Danish/LibreCAD/ts folder and use the Review tab where you find a link to Review Suggestions. You are guided to the first translation text with suggestions. Click on the green check mark rightward to accept a suggestion or enter a text that fits better and then click submit to save this translation. Take care about the fuzzy check box, if this option is checked, the translation is saved, but not used for production! To submit the translation for production use, the fuzzy option has to be unchecked! After submitting a translation you are guided to the next text with suggestions. If you find Spam suggestions, feel free to delete them to clean up the database. To translate other text which has no suggestions now, go to the Translate tab and use one of the translate links. Then you are guided to the strings which are fuzzy or not translated at all. If you have any questions about using the translation interface, please post your question in the LibreCAD-dev section of the forum. Thanks a lot for your contribution! Armin
Your google translate did not troll you and I have started as
official translator as you know.
But I am still looking for a way to correct special word(s) which I come up again in the Danish LibreCad. For example: forsæt must be corrected to fortsæt. How to do? Den 2014-04-25 14:11, R. van Twisk [via
LibreCAD] skrev:
-- Kind regards Normann Louis Olsen
Med venlig hilsen
Louis |
You can use the search function. On the top right side enter the misspelled word and you are guided direct to the string you want to correct.
If there are more occurrences, repeat the search for the next string. Armin
It worked!
Den 2014-04-28 08:44, LordOfBikes [via
LibreCAD] skrev:
You can use the search function. On the top right side enter the misspelled word and you are guided direct to the string you want to correct.But now please have a look on the attached file and help me to fix Google!! -- Venlig hilsen Normann Louis Olsen Dragevej 23, 4040 Jyllinge Mobiltelefon 29 82 73 08
Med venlig hilsen
Louis |
noolsen,
I'm sorry to say, but there is no solution for this at the moment. There are several issues with this. Our Pootle installation is not the newest version. This Google button worked with the free Google translate API v1, which was shut down in late 2011. That's the reason for the error message. The actual Pootle version supports the new Google translate API v2, but this is an paid only service, there is no free version. So for the moment the only way to use Google translate is to copy/paste the strings between LibreCAD translation server and a separate Google translator session. Regards Armin
