Default line width
Default line width
maurov
On layer specification, the default line width comes 0.00.
When printing, this 0.00 actually draws a thin line, even on screen and at a local inkjet printer.
What is your default line width, so I you can print and see at a acceptable way.
Re: Default line width
maurov
A reference from wikipedia:
Thickness for pens and plot: 0,13 mm Gray, 0,18 mm Red, 0,25 mm White, 0,35 mm Yellow, 0,50 mm Magenta, 0,70 mm Blue, 1,00 mm Green. In AutoCAD usually parts to be printed in black are drawn in 1 to 7 basic colors. Color layer: Green-Center, Magenta-Measure of length and Blue-Hidden.
Description Line thickness in mm Color Codes
Out Line     0.20 or 0.25 White, Cyan, Yellow,Blue
Hidden Line 0.00 or 0.05 Blue, Gray, 241
Center Line 0.10 or 0.15 Green, Red
Note         0.18 or 0.20 Cyan, Green, 41
Thin Line   0.00 or 0.05 Gray, 08, 111
Reference Line 0.000         Magenta, Gray
Hatch Line 0.000         Magenta, Green, Gray,red
Color-9 to 256 0.000
Dimension line
Leader Line with Arrows 0.000 Gray Color-9,or 8, Red
Text 0.18 or 0.20 Cyan, Green,
