Dimensionings are not updated
Hans-Werner
The position and also the value of a dimensioning is not automatically updated.
Will this be changed in the next version ?
I hope then I can also change the layer for a dimensioning.
Re: Dimensionings are not updated
sp1der
Hans
In Ubuntu 11.10 using the latest librecad update from 'daily' builds I can create a block and edit it and it is updated and for layers I can select a layer and modify it and it reflects the change OK.
What operating system  are you using?
For reporting bugs use:
For feature requests use:
*Note: you will need to register to use the above.
