Dimensions of slopes
Mauricio
Dear all
I have made the scheme of a roof observed from above. I use the "horizontal dimension" tool to measure the length of every timber. But since the timbers are not horizontal I have to correct the horizontal length values dividing by the cosine of the angles in the roof. Is there any automatic tool to do this task?
Thanks in advance
Re: Dimensions of slopes
Not the way you are hoping for. In edit - current drawing preferences - dimensions you can set a length factor. But this applies to all dimensions in the drawing. So for just a calculation drawing it might be alright, but not for a normal plan. Anyway for  plan view from above the projected distance is the right thing, the true length of a beam can only be shown and dimensioned in the section view.
