Dimensions without dimension.
Yeoman41
Hello there!
The last few days I am struggling with a very very stupid problem - I draw something (I try everything) and when it comes to put the dimensions, the result is arrows with no numbers at all, but instead there is a quite big box next to it without anything in it.
Please help, as it drives me mad. Apart form that the program is very good.
Thank you!
Re: Dimensions without dimension.
Gary S
Hello Yeoman41,
This might be an easy fix - the way you describe it, you might be working in 'draft mode'.  Check the title bar of the window, if "[Draft Mode]" appears there you need to switch back to the normal view.  To toggle in or out of the draft mode, select "View" from the menu and click "Draft", or press "Ctrl-D".  You can also use the toolbar button  to toggle the view...
Cheers...
Yeoman41
Gary, thank you very much mate! That worked and now I have proper dimensions at last. It took me a lot of trouble to put it right but to no avail so one more time thank you very much.
Cheers
sunggus
Nice.
Best regard,
aykan
i need help size always square and i do contrl+D no change many release tried all off them same when i prepare a layer then problem is occur.
