Do you use the cal command?
Next Topic
http://wiki.librecad.org/index.php/Calculator
I'm asking because it requires a 'space' character,
which means we can't use the space bar to submit a command.
This is unfortunate, especially for people coming from Autocad.
The idea I'm inclined toward is a separate input/widget for math,
with an automatic or quick copy feature.
It all depends on how people want to use it.
Let me know...
Re: Do you use the cal command?
In 2.2.0-alpha-24+ you can use space-bar to accept commands.
No need to erect any statues in my honor... ;D
The cal command now toggles the Calculator mode.
After toggling this mode on
input will be considered a mathematical expression
until the cal command is used again.
https://github.com/LibreCAD/LibreCAD/issues/764
Also note that space-bar will toggle free snap when the cmd line is empty;
this is intended to help with placing dimensions.
Cantar4
carved with our coper tools, obviously not
 but molded ?
note1
this tremendously helps with placing dimensions.
note2
why calling free snap which is in fact no snap at all,
would not snapfree or snapless be better names ?
"carved with our coper tools, obviously not
 but molded ?"
Or maybe 3D printed... ;-]
"this tremendously helps with placing dimensions."
"why calling free snap which is in fact no snap at all"
It might not be noticeable on a trackpad,
but there is proximal snapping with 'free snap' during mouse movement.
The name could probably still be improved.
