Edit dimension precision.
echo
How to edit dimension precision? By default it has four decimals and I do not need such precision. I would like to set custom dimension precision in the same drawing. For example, without and with two decimals. Is it possible?
Thanks
Re: Edit dimension precision.
You can only set the dimension precision for the whole drawing (in Options - Current drawing preferences - Dimensions), no individual settings possible. You may experiment with suppressing linear zeros.
