Error printing A3 paper format
10 messages Options
mickele
On my system (archlinux x86_64, LANG set to it_IT.utf8), if I choose a paper format different from A4, preview is right, but if I print on PDF, LibreCAD prints on A4 format.
Do you have any idea about possible causes?
Re: Error printing A3 paper format
Mickele,
are you sure that ypur printer driver doesn't scale it back?
I will try this a bit later today and see what happens.
Ries
http://librecad.1049103.n5.nabble.com/Error-printing-A3-paper-format-tp4511915p4511915.html
In reply to this post by mickele
Mickele,
i have been looking into this. And for me it happens aswell. This is because my printer (Epson scanner thingy) doesn't support. So the dialog goes back to something that's valid.
However, when I set the dropdown to A3 I can perfectly print on A3.
I will push a couple of updates regarding this, mainly to get rid of some q3support related items.
Ries
mickele
Thanks for your help.
I updated librecad from git, but I still have the same problem.
Also if I print on file, drawing is cut to A4 format.
mickele
mickele
Problem seems caused by Qt.
Method QPrinter::setPaperSize() doesn't work when printing on PDF (see qprinter.cpp).
Quite strange...
Mickele,
where exactly do you see this in qprinter.cpp?
Ries
Quite strange...
http://librecad.1049103.n5.nabble.com/Error-printing-A3-paper-format-tp4511915p4529625.html
mickele
Mickele,
that macro points to:
#define ABORT_IF_ACTIVE(location) \
    if (d->printEngine->printerState() == QPrinter::Active) { \
        qWarning("%s: Cannot be changed while printer is active", location); \
        return; \
So I think as long as the printer is not active,
I should beable to set the paper size.
Ries
On Jun 27, 2011, at 3:13 PM, mickele [via LibreCAD] wrote:
Line 1136 in
http://www.qt.gitorious.org/+wkhtml2pdf/qt/wkhtmltopdf-qt/blobs/076c6564fb466aa28b485bd927ac7fd0449097fd/src/gui/painting/qprinter.cpp
http://librecad.1049103.n5.nabble.com/Error-printing-A3-paper-format-tp4511915p4529662.html
mickele
Yes, you're right.
However the problem is in Qt. I wrote a simple program that prints a word on an A3 paper.
On other system (e.g. windows) everything works fine, on my archlinux 64 bit it creates an A4.
Here's some code:
    QPrinter * printer = new QPrinter();
    printer->setPaperSize( QPrinter::A3 );
    qWarning("before: %d", printer->paperSize() );
    // it prints 8, the right value
    if( printer->isValid() ){
        QPrintDialog * dialog = new QPrintDialog( printer, this );
        // I set pdf as printer, but I don't change the paper size
        if( dialog->exec() == QDialog::Accepted ){
            qWarning("after: %d", printer->paperSize() );
            // it prints 0, A4 format
            QTextDocument doc;
            doc.setPlainText( trUtf8("bye") );
            doc.print( printer );
    delete printer;
This can be a bug in qt-4.7.3 or a bug in qt package available on archlinux.
maqifrnswa
On Mon, Jun 27, 2011 at 4:35 PM, mickele [via LibreCAD]
<[hidden email]> wrote:
> Yes, you're right.
> an A3 paper.
> it creates an A4.
I think you're right, it's a qt bug - don't know how much we can do with that:
http://www.eaglecentral.ca/forums/index.php?t=msg&goto=132446&S=576ba10e86783cc00e88495196dc6082
I can't find a reference in qt's bugs, however . . .
