Export to PDF - Too Large File Size
kbharaninath@gmail.com
Whenever I Export to PDF, the file size is extremely large. For example, my Drawing in LibreCAD is just 115 kb but when I export to PDF, the file size is 11 MB. Can someone help me how I can get a smaller file size? Am I having some setting wrong?
Kindly advise.
Regards,
KB
Regards,
KB
Re: Export to PDF - Too Large File Size
Difficult to say what's the reason without the file.
Do you have an image in it?
A lot of text?
Blocks inserted repeatedly many times?
Large areas of hatching, maybe even very dense? In the pdf every line will be an extra object.
Maybe you can't make it smaller. You may try an external pdf printer to see if the result is better.
A lot of text?
You are right, blocks are repeated. The dxf file is only 100 to 200 KB. So, was wondering why the pdf file is so huge. There is a 264 kb dxf file that came out as 23 MB pdf file.
Regards,
KB
Without looking into code, I assume that the PDF is created as pixel image.
So a DXF file describes each entity with few lines of ASCII code. But the PDF will depend on the form factor of the drawing. The bigger the drawing in the sense of absolute dimensions, the bigger the PDF will be.
I am using the following version of LibreCAD
Version: 2.1.3
Compiler: GNU GCC 4.9.1
Compiled on: Sep 23 2016
Qt Version: 5.4.1
Boost Version: 1.60.0
System: Windows
I used File -> Export -> Export as PDF
Regards,
KB
When you open a LibreCAD pdf export in Inkscape, you can see it's vector graphics. The whole drawing seems to be one entity at first, you have to ungroup (explode) it to get to the various elements.
