Export to different file formats
9 messages Options
MHz
MHz
First of all I'm a newbee.
I have designed a frontplate wich looks pretty good and fit perfect. Now I want to put labels on the real frontplat made from aluminium by using thermo transfer method. This means I have to print a mirrored image of the front plate with all the labeling.
As far as I know librecad can not mirror text. So I tried to export my drawing instead of .dxf to an other file format and in turn mirror this one. Tried .jpg, .png and .tif. However all I got was empty files. Opening those file wit photoshop shows nothing. The good thing about this: photosop reports no error. However this is less then I've expected.
Thanks for your advice
Re: Export to different file formats
You can explode text into lines and then make the offset
MHz
MHz
remember I'm a newbee.
How do I explode text into lines? Offset means mirroring?
Thank you for your patience
2013/10/29 Rallaz [via LibreCAD] <[hidden email]>
http://forum.librecad.org/Export-to-different-file-formats-tp5709089p5709090.html
To unsubscribe from Export to different file formats, click here.
Sorry:
You can explode text into lines and then make the MIRROR
1. menu "Edit->Explode"
2. menu "Edit->Mirror"
MHz
MHz
Fine thank you a lot Rallaz I'll try this.
However question remain what do I wrong in exporting librecat output into other than .dxf file format.
Thanks again
  MHz
MHz
MHz
Hi Rallaz
thank you for your patience. I'm still struggeling with two issues:
1) How to save a drawing in a fileformat other than .dxf e.g. .jpg .tif you name it
2) exploding text to something I (that means librecad) can mirror
Sorry for stupid questions
Thanks a lot
MHz
Main menu: File->Export
Main menu:
Modify->Explode Text to Letters
MHz
MHz
Great! Explode text into letters works, thank you!
2nd question was how to export into a different file format. I just click "Expoer..." from File menue, choose a file name, .jpg as format and set resolution to 600 all I get is an empty file (with the correct file name and extension)
Whats wrong with my settings?
regards
MHz, still a newbee
MHz
MHz
sorry for all the fuss
every thing works fine after installing the latest version
regards MHz
2013/10/30 MHz [via LibreCAD] <[hidden email]>
regards
MHz, still a newbee
http://forum.librecad.org/Export-to-different-file-formats-tp5709089p5709107.html
