Hatching "Solid Fill" Pattern Still Failed with LibreCAD 2.2.0 RC1
1 message Options
sunggus
Hope anyone can help me with this issue or I hope this info will be a feed back for developing for 2.2.0 Final Release.
As you may see, while I draw "a pipe" then I hatched with Solid Fill pattern, it worked but strange. It is not as expected. But when I fill with ANSI 31, it works perfectly and I can see that now the hatching is better than LibreCAD 2.1.3. But when I hatched for another three shapes, the hatching pattern both for solid fill and ANSI 31 are working perfectly.
Hatching "Solid Fill" pattern is strange.
Hatching "ANSI 31" pattern is working perfectly.
Every kind help will be appreciated.
Best regard,
