Help not showing in daily builds (was: Questions for a New LC user. Layers, Print window, Help files.)
2 messages Options Options
maqifrnswa
On Thu, Apr 19, 2012 at 2:34 PM, R. van Twisk [via LibreCAD]
<[hidden email]> wrote:
> We do have something in place for the helpfile at the moment
> and it should currently never show "Bugger, I couldn't find the helpfiles on the filesystem"
> This is what it should show:
> If it's showing the 'bugger' messages then we need to ask what operating system,
> from there we can start figuring out why it shows that.
> usually it's because :
> 1) The helpfile wasn't really found
> 2) sql3 is not found
It's in the daily builds... someone should fix that {looks in the mirror}...
I'll take a look at it
Re: Help not showing in daily builds (was: Questions for a New LC user. Layers, Print window, Help files.)
Scott,
make sure that this command can run fine: qcollectiongenerator LibreCADdoc.qhcp
See line 10 and 11 of : postprocess-unix.sh
It generates the helpfiles into a sqlite3 database file with the extension *.qhc and *.qch
The OSX script copies them to the right directory using the following two lines
cp librecad/support/doc/*.qhc $RESOURCEDIR/Resources/doc
cp librecad/support/doc/*.qch $RESOURCEDIR/Resources/doc
I think these two lines should be added to postprocess-unix.sh to create a complete package aswell...
The background of the script are so that the user can compile and run LibreCAD without doing a full installation.
Ries
<<a href="x-msg://299/user/SendEmail.jtp?type=node&amp;node=5652567&amp;i=0" target="_top" rel="nofollow" link="external">[hidden email]> wrote:
