Help with perpendicular snap
fernandohildebrand
Hi al...
Need some help with the code here. heres what i got so far:
rs_entitycontainer.cpp ->
RS_Vector RS_EntityContainer::getNearestPerpendicular(const RS_Vector& coord
    RS_Vector closestPoint(false); // closest found endpoint
    RS_VectorSolutions sol;
    RS_Entity* closestEntity;
    closestEntity = getNearestEntity(coord, NULL, RS2::ResolveAll);
    if (closestEntity!=NULL) {
        for (RS_Entity* en = firstEntity(RS2::ResolveAll);
             en != NULL;
             en = nextEntity(RS2::ResolveAll)) {
            if (
                    !en->isVisible()
                    || en == closestEntity
                    || en->rtti() == RS2::EntityPoint         /**Point*/
                    || en->getParent()->rtti() == RS2::EntityInsert         /**Insert*/
                    || en->getParent()->rtti() == RS2::EntityText         /**< Text 15*/
                    || en->getParent()->rtti() == RS2::EntityDimAligned   /**< Aligned Dimension */
                    || en->getParent()->rtti() == RS2::EntityDimLinear    /**< Linear Dimension */
                    || en->getParent()->rtti() == RS2::EntityDimRadial    /**< Radial Dimension */
                    || en->getParent()->rtti() == RS2::EntityDimDiametric /**< Diametric Dimension */
                    || en->getParent()->rtti() == RS2::EntityDimAngular   /**< Angular Dimension */
                    || en->getParent()->rtti() == RS2::EntityDimLeader    /**< Leader Dimension */
                    ){//do not do intersection for point for Spline, Insert, text, Dim
                continue;
            sol = RS_Information::getPerpendicular(closestEntity,
                                                  en);
            closestPoint = sol.getClosest(coord);
    return closestPoint;
rs_information.cpp->
RS_VectorSolutions RS_Information::getPerpendicular(RS_Entity* e1,RS_Entity* e2){
    RS_VectorSolutions ret;
    RS_VectorSolutions t1;
    RS_VectorSolutions t2;
    if (e1==NULL || e2==NULL ) {
        RS_DEBUG->print("RS_Information::getPerpendicular() for NULL entities");
        return ret;
    if (e1->getId() == e2->getId()) {
        RS_DEBUG->print("RS_Information::getPerpendicular() of the same entity");
        return ret;
    // unsupported entities / entity combinations:
    if (
        e1->rtti()==RS2::EntityText || e2->rtti()==RS2::EntityText ||
        isDimension(e1->rtti()) || isDimension(e2->rtti())) {
        return ret;
    // arc,circle,elipse/arc,circle,elipse
    if(
        (e1->rtti()==RS2::EntityArc || e1->rtti()==RS2::EntityCircle
            || e1->rtti()==RS2::EntityEllipse) &&
        (e2->rtti()==RS2::EntityArc || e2->rtti()==RS2::EntityCircle
            || e2->rtti()==RS2::EntityEllipse)) {
        t1 = e1->getTangentPoint();
        t2 = e2->getTangentPoint();
        if(t1.dotP(t2)==0){
            ret = container->getNearestPointOnEntity(e1);
            return ret;
    // line/arc,circle,elipse , arc,circle,elipse/line
    if(e1->rtti()==RS2::EntityArc || e1->rtti()==RS2::EntityCircle
            || e1->rtti()==RS2::EntityEllipse){
         t1 = e1->getTangentPoint(e1->getNearestPointOnEntity(e2));
         if(t2.dotP(t1)==0){
             return ret;
     else if(e2->rtti()==RS2::EntityArc || e2->rtti()==RS2::EntityCircle
            || e2->rtti()==RS2::EntityEllipse){
         t2 = e2->getTangentPoint(e2->getNearestPointOnEntity(e1));
         if(t1.dotP(t2)==0){
             return ret;
    //line/line
    t1 = e1;
    t2 = e2;
    if(t1.dotP(t2)==0){
        return ret;
    return ret;
See, my main problem is getting the tangent lines/vector/points from the entities on information so I can do a DotProduct, I still dont get vetor_solutions...
Help please?
Fernando da Motta Hildebrand
Re: Help with perpendicular snap
Please generate a patch (against master branch) or, send a pull request to my repo:
github.com/dxli/LibreCAD
Thanks,
Dongxu
On Fri, Feb 17, 2012 at 2:09 PM, fernandohildebrand [via LibreCAD] <[hidden email]> wrote:
Hi al...
             en != NULL;
            if (
                    !en->isVisible()
                continue;
                                                  en);
        return ret;
        return ret;
    if (
        return ret;
    if(
        if(t1.dotP(t2)==0){
            return ret;
         if(t2.dotP(t1)==0){
             return ret;
         if(t1.dotP(t2)==0){
             return ret;
    //line/line
    t1 = e1;
    t2 = e2;
    if(t1.dotP(t2)==0){
        return ret;
    return ret;
Help please?
http://librecad.1049103.n5.nabble.com/Help-with-perpendicular-snap-tp5493585p5493585.html
Dongxu Li, Ph.D.
www.librecad.org
fernandohildebrand
Ive cloned the source. dont know how to do a pull request on github....
2012/2/17 dxli [via LibreCAD] <[hidden email]>
Thanks,
Dongxu
Hi al...
             en != NULL;
            if (
                    !en->isVisible()
                continue;
                                                  en);
        return ret;
        return ret;
    if (
        return ret;
    if(
        if(t1.dotP(t2)==0){
            return ret;
         if(t2.dotP(t1)==0){
             return ret;
         if(t1.dotP(t2)==0){
             return ret;
    //line/line
    t1 = e1;
    t2 = e2;
    if(t1.dotP(t2)==0){
        return ret;
    return ret;
Help please?
Dongxu Li, Ph.D.
www.librecad.org
http://librecad.1049103.n5.nabble.com/Help-with-perpendicular-snap-tp5493585p5493619.html
the easiest is to generate a patch. Some ideas like:
1, git clone git@.../LibreCAD/LibreCAD.git
2, cd LibreCAD
3, do your changes. For simplicity, you don't commit your changes to git yet
4, git diff
or: git diff HEAD > /tmp/mypatch.patch
If you do commit your changes in steps, git log, and supply a commit number(hash) instead of HEAD
http://githowto.com/
Thanks,
Dongxu
On Fri, Feb 17, 2012 at 3:18 PM, fernandohildebrand [via LibreCAD] <[hidden email]> wrote:
Thanks,
Dongxu
Hi al...
             en != NULL;
            if (
                    !en->isVisible()
                continue;
                                                  en);
        return ret;
        return ret;
    if (
        return ret;
    if(
        if(t1.dotP(t2)==0){
            return ret;
         if(t2.dotP(t1)==0){
             return ret;
         if(t1.dotP(t2)==0){
             return ret;
    //line/line
    t1 = e1;
    t2 = e2;
    if(t1.dotP(t2)==0){
        return ret;
    return ret;
Help please?
Dongxu Li, Ph.D.
www.librecad.org
http://librecad.1049103.n5.nabble.com/Help-with-perpendicular-snap-tp5493585p5493849.html
Dongxu Li, Ph.D.
www.librecad.org
In reply to this post by fernandohildebrand
Assuming you did these steps : http://help.github.com/fork-a-repo/
Then you can push your changes back to your repo.
Then there is a button on github called 'send pull request'.
This will create a diff for you and send it to dli.
You can also do a git diff > out.patch and send that.
2012/2/17 dxli [via LibreCAD] <<a href="x-msg://190/user/SendEmail.jtp?type=node&amp;node=5493849&amp;i=0" target="_top" rel="nofollow" link="external">[hidden email]>
Thanks,
Dongxu
Hi al...
             en != NULL;
            if (
                    !en->isVisible()
                continue;
                                                  en);
        return ret;
        return ret;
    if (
        return ret;
    if(
        if(t1.dotP(t2)==0){
            return ret;
         if(t2.dotP(t1)==0){
             return ret;
         if(t1.dotP(t2)==0){
             return ret;
    //line/line
    t1 = e1;
    t2 = e2;
    if(t1.dotP(t2)==0){
        return ret;
    return ret;
Help please?
Dongxu Li, Ph.D.
www.librecad.org
To start a new topic under LibreCAD-dev, email <a href="x-msg://190/user/SendEmail.jtp?type=node&amp;node=5493849&amp;i=1" target="_top" rel="nofollow" link="external">[hidden email]
To unsubscribe from LibreCAD-dev, <a href="x-msg://190/" target="_blank" rel="nofollow" link="external">click here.
