How can I write blocks into individual files?
wk
wk
Hallo.
I have a drawing with many blocks.
How can I write this blocks as a single block in the library?
Thank you very much
Vielen Dank.
wk
Re: How can I write blocks into individual files?
ClaudeQC
On 17/11/2011 11:25, wk [via LibreCAD] wrote:
 > I have a drawing with many blocks.
 > How can I write this blocks as a single block in the library?
- From my knowledge, there is no block command to write a block
   to a file.
   However, you can use "Edit"->"Copy" and "Edit"->"Paste" to
   copy a block from the edit block window to another drawing
   window.  Then, save the drawing window using it as your block
   container (file).
P.S.:  If you want, you can fill a feature request here:
Claude
wk
wk
I've written a feature request.
Thank you
wckl
