How to I edit properties of MultiLine text?
Todd
Hi All,
How do I change the properties of a previously created multiline text object?  (I forgot to put the angle of rotation in it.)
Many thanks,
-T
Re: How to I edit properties of MultiLine text?
rolgiati
On Thu, 22 Jan 2015 19:35:18 -0700 (MST)
Select the layer it is on, and rotate layer ?
Cheers,
Ron.
                      A good question is never answered.
                 It is not a bolt to be tightened into place
                but a seed to be planted and to bear more seed
              toward the hope of greening the landscape of idea.
                                                  -- John Ciardi
In reply to this post by Todd
It looks like Modify -> Properties doesn't work for MTEXT entities.
As work around you can use the Modify -> Rotate tool to rotate the text.
[Solved] Re: How to I edit properties of MultiLine text?
Todd
I was able to set the angle with Modify --> Properties.   Maybe it is your revision that is giving you problems?
Thank you all for the Help!
Re: [Solved] Re: How to I edit properties of MultiLine text?
Ah, I see, I was fooled by different work flow.
For most modify actions you must select the tool, then the selection tool bar appears to select the entities to modify.
As the selection tool bar doesn't appear with Properties tool, I supposed a bug.
