How to trace over an image?
librecaduser
hi:
I can import an image into LibreCAD,
but I am not able to trace(draw) over the image outlines.
Thank you.
Re: How to trace over an image?
humulus
You mean you don't see the lines you draw?
Or did you enable one of the snap functions?
librecaduser
Once I imported the image,
I tried to draw some lines over the image.
Bit the lines does not show up.
OK, now I see my problem when I removed the image.
The CAD line is white, and the image is also white.
How do I change the color of line to black, blue, or green or something else.
Can I make the lines thicker?  How?
I also like to change the back ground to white or something else.
Thank you.
rolgiati
On Tue, 12 Jul 2016 08:35:07 -0700 (MST)
> else.
try in the Layer properties. (right-click on the layer, Edit Layer
Cheers,
Ron.
                               The older I get,
                           the better I used to be.
