Insert an image with a given size
1 message Options
Christian
I want to insert an image I have resized with Gimp so it has the dimensions I want in millimetres.
The problem is that when I insert it the size in LC is, in millimetres, equal to the pixel value in Gimp.
For instance, I resize the Photo in Gimp so that it is 245 x 135 mm (i.e. 1736 x 955 px), then I insert it in LC and expect it to be 245 x 135 mm, instead it is 1736 x 955 mm.
Of course I can either resize it in Gimp so that it is 245 x 135 px and then insert it, or I can insert it larger and scale it dow.
Would it not be more logical though to insert an image with the actual size created on whatever Image Manipulation Program used?
Regards,
Christian
