Keyboard shortcuts
7 messages Options Options
Keyboard shortcuts
Dayco
My question is : I appreciate there is not only drop down menues but also icons to select functions but I just wondered if there are also keyboard shortcuts?
Thanks for any help Duncan
Re: Keyboard shortcuts
We should implement GUI support to configure shortcuts.
Another way to trigger actions is by the command line interface, and available commands can be found in source code:
rs_commands
You may also define your command aliases by changing the alias configuration file and restart LibreCAD:
 * In OS_WIN32 "%HOME%\local configuration\application data\LibreCAD\librecad.alias"
 * In OS_MAC "$HOME/Library/Application Support/LibreCAD/librecad.alias"
 * In OS_LINUX "$HOME/.local/share/data/LibreCAD/librecad.alias"
Dayco wrote
terryduran
1 post
This post was updated on Dec 05, 2015; 6:40pm.
In reply to this post by Dayco
... <spam removed> ...
Dayco
Thanks for replies.  I am afraid the command line method is a tad daunting to a relative newbie to computing.
As regards the advice to 'study' the shortcuts I am assuming you mean discovering the keys by trial and error? as I see no reference to a shortcut list anywhere.
Thanks
In reply to this post by terryduran
The said alias file is plain text, but doesn't contain much information.
The best way is to read the beginning of this file:
https://github.com/LibreCAD/LibreCAD/blob/master/librecad/src/cmd/rs_commands.cpp
TODO: we should add this information to wiki.librecad.org
terryduran wrote
Yes they are kyboard shortscuts .Many other keys are using for the shortcuts functions.It will very benfit at the time mouse stuck.YOu must study about keyboard short cuts keys.
Dayco
Thanks,
I shall try and understand the instructions.
Hi Dayco,
Just want to make the file reads easier, and hope you already figured out from your side.
look at one example from the said URL,
    cmdTranslation.insert("polyline", tr("polyline"));
    mainCommands.insert(tr("polyline"), RS2::ActionDrawPolyline);
    cmdTranslation.insert("pl", tr("pl"));
    shortCommands.insert(tr("pl"), RS2::ActionDrawPolyline);
tr("polyline") means the translated/localized string for "polyline"
the first line links the "polyline" with the translated string: cmdTranslation.insert("polyline", tr("polyline"));
The second line links the translated string to the the Action to take RS2::ActionDrawPolyline (which is mostly self-explaining by name).  mainCommands.insert(tr("polyline"), RS2::ActionDrawPolyline);
following two lines are essentially the same, but in a category of "short commands" instead of full "commands", as "pl" vs "polyline"
then, you can edit your own command alias file to link your own alias commands to existing commands.
Dayco wrote
Thanks,
