Layer list
7 messages Options
Layer list
Sansol
I'm trying to figure out how to change the order my layers are organized in the layer list. "Drag and drop" is clearly not it. What am I overlooking?
Re: Layer list
I haven't found a way either. It seems not to be possible.
Re: Layer list
Gary S
It looks like layers are listed alphabetically and / or numerically.  I tried number layers, e.g. 1- Notes, 2- Construction, 2.1- Exterior, 2.2- Interior, 4- Electrical, 5- Dimensions, ... and it seemed to do the trick.  If there are more than ten, you can either start with 01, 02, ..., 11, 12, ... or use a decimal 1.0, 1.1, 1.2, 2.0, 2.1, ...
Re: Layer list
The layer list is sorted alphabetical, you can't change this. But you can add a prefix to your layer names to get the order you want.
Different from DTP or graphics software in CAD the layer order doesn't influence the drawing order.
Re: Layer list
Sansol
Thanks all. So the question is really - how do I influence the drawing order? In this particular drawing I have placed a background image and drawn some changes to a common area in my neighbourhood. A poor attempt at some landscape architecture. However, my hatches appear beneath this image and my outlines appear above. I screwed up somewhere and I'd hate to start all over again. Any tips/ideas?
2017-10-29 20:38 GMT+01:00 LordOfBikes [via LibreCAD] <[hidden email]>:
http://forum.librecad.org/Layer-list-tp5715428p5715431.html
To unsubscribe from Layer list, click here.
Re: Layer list
There is a tool for drawing order that isn't shown in the out of the box appearance of LC 2.1.3. Go to Widgets - Toolbars - Order to activate it.
But there is another obstacle. Bitmap images prevent proper selection of entities other than pulling up a window around them, so you can't edit them properly. I don't understand entirely what's going on here, it's a bug. I have played around a bit and it's best to have the image on a different layer, the interference exists even if that layer is locked, but you can make it invisible, then it's ok. This way I have managed to get the hatching to the top.
Re: Layer list
Saboia
If you use capitalized first letter and lower case in layers name, there will be two sort, capitalized first.
