Lengthen tool's strange behaviour on ellipses
Christian
In the version 2.1.0-alpha recently downloaded and while testing the Lengthen tool I just found the following defect:
-working on an arc of ellipse, whatever value I enter, positive or negative, the action is only reducing the arc, never lengthening it. Which it does on an arc of a circle.
-working on a full ellipse it will start by removing about 1/4 of it and then in repeating the action it will remove the set value, never add. On a full circle, this tool has no action which seems normal to me.
I am working on Windows 10
Regards,
Christian
Re: Lengthen tool's strange behaviour on ellipses
I will have a look on the ellipse side.
Merci!
Christian wrote
Regards,
Christian
In reply to this post by Christian
This turns out to be a clear mistake in the ellipse part of lengthen processing.
Looks like we will have to do a new implementation.
Christian wrote
Regards,
Christian
fixed in both 2.0 and master branches:
https://github.com/LibreCAD/LibreCAD/commit/bfa456370ae03080f70829e72664ecb27334429c
The new implementation is much simpler in logic.
Merci!
Christian wrote
Regards,
Christian
Christian
Bonjour Dongxu,
I will no longer use the expression "this is Chinese to me"  but your attachment on github does not belong to the few foreign languages I manage.
Maybe you can let us know when it will be implemented on a newer version?
Enjoy your Sunday,
Christian
It will be in the latest alpha version (already avialable).
