LibreCAD User Manual New Content 2/14/13
45 messages Options
123
Re: LibreCAD User Manual New Content 2/14/13
Stano Sitar
Hi.
Some time ago I started to write manual from a point of view of AutoCAD user used to working with a commandline.
At this moment it is kind-of reference manual describing all the commands that can be entered from a commandline with all the options.
Recently I have added some stuff and I plan to enhance it a bit more.
Please feel free to use any of that stuff for your manual.
http://wiki.librecad.org/index.php/A_short_manual_for_use_from_the_command_line
Stano
Bob
Bob
In reply to this post by DanD
Hi Dan,
Thank you for the kind comments. I am always open to making edits to the manual.
Bob
sp1der
Hello Bob
I've re-added your manual to the wiki after having problems with it before. All that needs doing now is to add the images:
http://wiki.librecad.org/index.php/LibreCAD_version_2,_users_Manual/Guide_-_by_Bob_Woltz
Bob
Bob
Hi Dan,
All edits will be helpful. I am glad you like the manual it was sorely needed.
Bob
hsrai
If original author (Bob) wishes to develop this guide / manual in collaborative manner, then there are many tools at our disposal. Google Doc (Google Drive) may be one option. We can upload doc file there, any one or invited (restricted) persons may be allowed to add / edit content. It saves different version and one can roll back also.
Document may be exported to any format odt / pdf.
Even one can comment and have discussion there.
Wiki may be other option.
H.S.Rai
H.S.Rai
Rai,
I have never worked on google docs, so i cannot comment on that.
However, the wiki didn't work well for us...
We tried to use the wiki, and I make the terrible decision to use MediaWiki for that. (my …. what a terrible wiki system is that!!)
At some point I was spending more time weeding out spam from the wiki then that there was usefull information, so now
we have a registration system, unfortunately the system doesn't send me any emails :( media wiki has a endless number of configurations,
but unfortunately you keep hacking PHP together until it works.
Additionally, there aren't any good systems to generate a HTML/PDF from the wiki without again writing endless lines of PHP
codes to make it work.
So, I am all for using Google docs and it would even be better if we could generate HTML from it. The reason is that
we (used??) to have a lot of people from Africa where stable internet isn't available and there only option for a manual
is having this part of the download using the help system.
At least I would include teh PDF that can be opened using the default PDF viewer using the help button.
H.S.Rai
http://forum.librecad.org/LibreCAD-User-Manual-New-Content-2-14-13-tp5707420p5707804.html
To start a new topic under LibreCAD Manual/Wiki topics, email [hidden email]
hsrai
<snip>
In that case, you can try with link below. I have uploaded copy of manual, and anyone (even without Google account) can contribute.
https://docs.google.com/file/d/0B2KtjpkIy9jKRmctNGNqU1p4YTQ/edit?usp=sharing
doc to html or pdf to html is possible.
H.S.Rai
H.S.Rai
hsrai
Try following link in place of above / previous one.
https://docs.google.com/document/d/1MT8QoQs9uPYRRPRMeWStaMpFzK8Dzmd-imkjmyqep8s/edit?usp=sharing
With this you can download pdf, html, doc, odt.
H.S.Rai
H.S.Rai
In reply to this post by hsrai
Rai,
be careful with enable contributions on these documents,
spam can very easily be added then, same happened with the wiki.
I could open the document just fine.
On Mar 29, 2013, at 1:32 PM, "hsrai [via LibreCAD]" <[hidden email]> wrote:
<snip>
H.S.Rai
http://forum.librecad.org/LibreCAD-User-Manual-New-Content-2-14-13-tp5707420p5707808.html
hsrai
It was just to show the capability of tool. Can I disable this link, and edit access will be only to few, on their email basis, rest can only read and comment.
Give me your (of who are interested in contributing this book) email offline at hardeep [DOT] rai [AT] gmail [DOT] com
H.S.Rai
H.S.Rai
hsrai
hsrai wrote
Found it "Hard Formatted", that mean we can not create "Table of Contents" from it, and look will also be bad, export to many other format will be problem. So, I started changing that. For the time being, I will not correct/add content, but try to improve format, structure of document.
H.S.Rai
H.S.Rai
sp1der
Hi Rai
Google docs is definitely the way to go, we should forget about the wiki.
What do you mean you cannot insert table of contents?
hsrai
See it, as published on Internet at:
 https://docs.google.com/document/d/1MT8QoQs9uPYRRPRMeWStaMpFzK8Dzmd-imkjmyqep8s/pub
To create "Table of Content" (ToC) automatically, we need to use style, mean we need use H1, H2, H3 for Chapter Heading, Main heading, Sub-heading and so on, which were not there. I have made that, so you can see ToC, there.
We should never use Hard Formatting, we should always use Style.
@ BoB,
Please see organisation, if I did something wrong, change it, then refresh ToC, and see it is as per your objectives / goal and design.
H.S.Rai
H.S.Rai
umbauwfb
In reply to this post by Bob
Hello Bob,
first thanks for all the activities and the knowhow you put into this project! I saw your videos on YouTube, I saw your manual and I see the discussion and all your work here. Chapeau!
I have a problem because I miss (or do not find) a command in LibreCAD. Hopefully you can help!
I am a machine knitter and am member of a machine knitting group at Yahoo! I plan all my garments with CAD and want to introduce LibreCAD as CAD-Software to the group.
I plan with autocad, but autocad is too expensive for all the group members. So I searched for a free solution and found LibreCAD. I have checked LibreCAD the recent days and found it has generally the ability to do all the needed steps. Perfekt!!
Just miss one thing: with command "scale" you can scale entities with ONE factor in "X" and "Y" dimension. We would need TWO factors: One factor for "X" and one factor for "Y".
The diffficulty comes with the pattern. We have standard patterns and create new patterns. Patterns rough said are a block of black and white cells in a distinct adjustment. It is no difficulty to draw a pattern, build a block and multi-copy it into the garment.
The difficulty comes with the differnt wools and tensions that produce different big meshs (cells). So we have to draw the pattern always new from zero because we cannot scale the mother-pattern from e.g. 1x1mm cells to e.g. 2.456mmx4.328mm cells which is needed for the distinct wool of a project.
This makes the work very uncomfortable and hard. I hope very much that you have a solution for us!
Thanks in advance
Harry, Lueneburg, Germany
cranky
Can this not be done with the options in the 'Scaling Options' dialog?
You can enter independent X and Y scale factors here.
AW: LibreCAD User Manual New Content 2/14/13
umbauwfb
First thanks for your answer,
have you a different version of LibreCAD?
Please see my scale-window attached
Best regards
Von: cranky [via LibreCAD] [mailto:[hidden email]]
Gesendet: Sonntag, 9. Juni 2013 16:11
An: umbauwfb
Betreff: Re: LibreCAD User Manual New Content 2/14/13
http://forum.librecad.org/LibreCAD-User-Manual-New-Content-2-14-13-tp5707420p5708264.html
To unsubscribe from LibreCAD User Manual New Content 2/14/13, click here.
Scale different in two dimensions.pdf (51K) Download Attachment
Re: AW: LibreCAD User Manual New Content 2/14/13
cranky
Currently I am using the latest release, see here:
http://librecad.org/cms/home/get-help/forum.html
AW: AW: LibreCAD User Manual New Content 2/14/13
umbauwfb
Do you use version
2.0.0rc1
modified 2013-06-09
or
1.0.3
modified 2013-05-08
Gesendet: Montag, 10. Juni 2013 10:30
An: umbauwfb
Betreff: Re: AW: LibreCAD User Manual New Content 2/14/13
http://forum.librecad.org/LibreCAD-User-Manual-New-Content-2-14-13-tp5707420p5708282.html
hsrai
In reply to this post by umbauwfb
I used:
Version: master
SCM Revision: 2.0.0beta1-137-gf26a9af
Compiled on: Apr 4 2013
have different scale in X and Y direction.
H.S.Rai
umbauwfb
Thanks for your help,
problem is solved!
Von: hsrai [via LibreCAD] [mailto:[hidden email]]
Gesendet: Montag, 10. Juni 2013 13:44
An: umbauwfb
I used:
Version: master
H.S.Rai
http://forum.librecad.org/LibreCAD-User-Manual-New-Content-2-14-13-tp5707420p5708294.html
123
