LibreCAD and WGS84
LibreCAD and WGS84
brookland
Is it possible to set the coordinates to use the WGS84 standard so they match with the Earth's coordinates?
I use kml files that I convert to dwf files to edit in LibreCad. It works for me, except the distances and scale are way off.
I'd like to be able to do things like take a line I imported in that shows the edge of a river, and offset another line 150' away. And, I'd like to draft the position of two buildings and do things like measure the distance between them.
Lev
Re: LibreCAD and WGS84
Lev
You might consider using GQIS for this kind of work.
http://qgis.org
Levente
On Fri, Aug 4, 2017 at 1:59 AM, brookland [via LibreCAD]
> between them.
> ________________________________
> If you reply to this email, your message will be added to the discussion
> below:
> http://forum.librecad.org/LibreCAD-and-WGS84-tp5715145.html
> To start a new topic under LibreCAD-user, email
> [hidden email]
> To unsubscribe from LibreCAD-user, click here.
> NAML
