LibreCAD-user
Users can post questions and comments about LibreCAD here.
The community chats on freenode.net in the #librecad channel:
http://webchat.freenode.net/?channels=librecad
Mailing List Options
Click "Options > Subscribe via email" to subscribe to this mailing list;
Click "Options > Post by email..." to get the email address of this mailing list;
You can post messages via email or through the forum interface below;
All web posts and emails are archived here.
1 ... 3456789 ... 49
Topics (1705)
Replies Last Post Views
JARRY Cotation by JARRY
1
fa201 by fa201
Andrew Janke Selection of entities intermittent by Andrew Janke
5
Ernst by Ernst
pFerdinand Installation v2.2.0 by pFerdinand
2
pFerdinand by pFerdinand
TarraT white UI in Windows and Dark UI in Linux, why? by TarraT
3
perepujal by perepujal
JARRY Format DWG en DXF by JARRY
4
JARRY by JARRY
tetukowski drawing a pattern of object as a function of its position by tetukowski
2
tetukowski by tetukowski
RGB MV reference point by RGB
3
LordOfBikes by LordOfBikes
Land Owner Select Window snap use - locked up drawing by Land Owner
0
Land Owner by Land Owner
Tnemmo One on one help for initial setup by Tnemmo
15
Tnemmo by Tnemmo
AM93 paramétrage de LibreCad by AM93
4
AM93 by AM93
spontarelliam export macro? by spontarelliam
3
Betonfrance MàJ des Blocks dans les dessins sous Librecad by Betonfrance
2
Betonfrance by Betonfrance
Renzo Copy by Renzo
5
Lloyd Knopp by Lloyd Knopp
Esche Hohenstein Could I trim one entity with multiple entities? by Esche Hohenstein
2
Esche Hohenstein by Esche Hohenstein
IntellectArchitects How to plot a survey plan using "Surveyor's Units" in LibreCAD by IntellectArchitects
11
Jaycad by Jaycad
Bojan Block origin when copied into new drawing ? by Bojan
1
Bojan by Bojan
kc8oye Paper size error? by kc8oye
0
kc8oye by kc8oye
Andreito Loading and printing files by Andreito
1
dellus by dellus
Paul S Drawing a tightening curve between a line and a circle... by Paul S
2
Paul S by Paul S
manolis940 Remove part of polyline according to another one by manolis940
0
manolis940 by manolis940
manolis940 Export coordinates from polylines by manolis940
2
karantois Bibliotèque by karantois
2
jmj "Cutting Lines " + Bug ? by jmj
3
Bryon Hatching by Bryon
1
gakbu by gakbu
lavadrifter Orthogonal issue in new version by lavadrifter
3
Astrid TAW by Astrid TAW
tytower How to copy between drawings by tytower
12
crispybrown by crispybrown
Günter Klappt das hier auf deutsch? Masslinien by Günter
2
Bebbspoke Print preview & pdf export ISO anomaly by Bebbspoke
2
Bebbspoke by Bebbspoke
Ingo N Text in draft mode only visible as frame, in print preview as text by Ingo N
2
Ingo N by Ingo N
Menna553 Area Of The Closed shape by Menna553
1
dellus by dellus
Rad Offset distance by Rad
1
Mal56 Bei Bemaßung werden keine Ziffern angezeigt by Mal56
2
Mal56 by Mal56
MisterEd Incomplete Drawing Printout {Solved] by MisterEd
3
MisterEd by MisterEd
MisterEd New text and lines are suddenly not as bright as rest of drawing [Solved] by MisterEd
2
gearify More modern DXF save version possible, or planned? by gearify
1
