Lines / Arc etc with arrows at end
JDelgado0311
Does any one know how specify that LibreCAD put an arrow at the end of a line?
Re: Lines / Arc etc with arrows at end
Lines and arcs with arrows you find in dimension menu or tool bar.
You can explode a dimension entity and delete the extension lines if absolutely necessary. But then you can't modify the arrow size. Modify the arrow size before exploding (Edit -> Current Drawing Preferences -> Dimensions -> General Scale).
For common entities, there is no such property. This is usually found in DTP software such as Inkscape.
Loading...
