Looking for a mechanical part to create a tutorial
9 messages Options
claus82
Hi guys, I'm looking for a mechanic drawing because I am gonna create some tutorials and later or soon I'll have to start to give some info about mechanical drawings...
BUT:
- I can use LC to create houses, so I can't think a good complex mechanic part that is reasonably realistic;
- I don't wanna break any copyright, so I can't download any drawing, I didn't find free downloadable ones;
Any help will be apreciated! a complete PDF draw or a JPG/PNG/BMP (with a list of layers, thicknesses and line type) would be really helpful.
Greetings
Claus
 the problem is that , so, if someone has something to give I'll focus on that drawing.
Honestly I could invent something but this is not my sector, so I could ...
Re: Looking for a mechanical part to create a tutorial
these drawings I use with my students, (in ACAD)CURSO.zip
claus82
Thanks man!!!
I'll start almost immediately!
Cla
claus82
Perdoname amigo, pero en estos dibujos veo que las capas TRAMA estan vacias... està bien asì?
Te pregunto esto porque tengo que ser seguro de hacer un buen trabajo.
Hay sombreados? Puede ser que vosotros habeis hecho vuestros propios sombreados y mi LC no lo tienes?
Aqui mi imagen con la capa TRAMAS activa y no activa.
(perdona también pero en ese teclado no tengo todos los acentos )
Te dijo hasta pronto Rallaz!
Cla
No, adjunto una impresión a pdf donde se ven todas las tramas.
El rayado oblicuo está realizado con la opción "definido por el usuario" que no es compatible con LC. Las otras puede ser un problema de escalas (este dibujo lo hize con ACAD r12) y ACAD usa dos tipos de escala ISO (mm) y pulgadas ('')
/* english version (not everyone knows spanish) */
No, attached a pdf print where you see all the hatches.
The oblique hatch is made with "user defined" option it is not compatible with LC. The other may be a scale problem (I did this drawing with ACAD r12)
printing attached a pdf where you see all the frames.
The oblique scratch is made with "user defined" is not compatible with LC. The other may be a scale problem (I did this drawing with ACAD r12) and ACAD uses two types of scale ISO (mm) and inches ('')
arqueta.pdf
The hatch called "sand" in LC are called AR_SAND in ACAD
LC version
arqueta2.dxf
Ciao,
claus82
Well, english then!
I can assume that the other drawings have the same issue.
Now I know how to proceed.
I'll start, when you have time, can U kindly post the other PDFs please?
Well, I hope that you find a kind of useful my tutorials...
Bye!
Cla
claus82
Friend, I solved using nanocad!
Claus
claus82 wrote
Well, english then!
is the best for me to learn English
Not all, "arqueta" is for learn how to apply hatches.
Another "problem" is advanced features in dimensions
Posted:
CURSO-PDF.zip
Well, I am an advanced (and old :-D ) CAD user, and teacher but only in spanish
but I'm sure many users will thank you, great work!!
Cheers,
