Modify Trim Two command ?
Jimts
I have been trying to figure out what this command does / how to use.  Is this explained anyplace?
ThankYou
Jim
Re: Modify Trim Two command ?
There is a paragraph about Trim in the wiki: Using_Trim
This command uses an entity for reference, where the modified entity is shortened/lengthened to. The reference entity is not modified with Trim command.
The Trim Two command modify both, the reference and the second entity. Use Trim Two on two crossing lines and both lines will be shortened to the intersection point. Depending on the position where you click the lines the result may be different. The part of the line where you click is kept, the part behind the intersection point is removed.
Jimts
Thanks Armin
I see now how Trim Two works.  I have been experimenting with various commands to see what all they do.  Trim Two had stumped me.
Much appreciated.
Jim
