Quantcast
New CAD User - Basics
swbouton
Hello,  I am interested in using LibreCAD for simple 2D floor layouts.  My experience is old and limited to a T-Square, eraser, paper and a sharp pencil.
Most drawing will be scaled to 1" = 10'.  For example, one project is for a layout that will be 70' long any 30' wide.  Others will mostly be smaller.
I need to have dimensions for the lines and rectangles I will use.
If it matters I will be printing all I can on 8.5" x 11" paper.
Am I using the right software to do this?
How to start?
Re: New CAD User - Basics
Yes, this is the right software to do this.
First you have to make the proper settings in Options - Current drawing preferences. I have prepared a template in inches according to your specifications. That's quicker than to explain everything. Delete the sample contents to make your own drawing and then save under a new name. Study the above mentioned settings I have made, you may experiment with changes. 'General scale 120' stands for 1" = 10', equivalent to 1:120. If you change the scale you would also have to change the page border box accordingly.
Have fun.
arch_inch_1_120_letter.dxf
swbouton
I appreciate this very much.  Thank you.
It comes up as a text file.  Should I make it so and where should I store it?
swbouton
Sorry, but I think I figured it out.  Thanks again!
Loading...
