Object Moving With Arrow Keys
ab-tools
I'm a relatively new user to LibreCAD, but I really like the program.
One thing I'm missing a lot is the option to move objects with the keyboard arrow keys "the last pixels":
after I moved the object to more or less the right position by mouse I want to move the very last "pixels" one-by-one via the arrow keys on the keyboard as it's basically impossible to accomplish that using the mouse.
There would just need to be a program setting where you can enter the resolution (like 1 mm or 0.1 mm) that you're currently working with and then one key press is moving the object by this resolution.
Is there a way already to accomplish this?
Best regards and thanks for this great program
Andreas
Re: Object Moving With Arrow Keys
Movement by snap points should be a good way to move entities precisely.
try to play with snapping to: grids, intersections, end points, center points
in addition, coordinates can be input from the command line
ab-tools wrote
Andreas
ab-tools
Hello dxli,
first thanks for your quick reply.
I indeed tested the snapping options, but this did not work for me due to a bug obviously - see my post here:
http://forum.librecad.org/Possible-Bug-with-Blocks-and-Snaps-td5711124.html
Does that work for you?
Best regards
Andreas
