Open dwg error Visual c++
2 messages Options Options
Najib
hello i can't open file dwg in librecad v2.1.3
Error microsoft visual c++ Runtime library
Thanks You for your answer
Re: Open dwg error Visual c++
Hello Najib,
the support for DWG format is still very basic in LibreCAD. I assume there are unsupported entities in the file which let the DWG import library crash. If possible you can upload the file here or send it private to me by mail, then we can use it to investigate the issue.
You can try to find a DWG to DXF converter and see if this works, then LibreCAD should be able to open the DXF file. Off the top of my head I think Theiga converter is often mentioned for this, but I can't say if this is actual and if it is still free.
