Portrait USA Letter Sized Printing Problems
1 message Options
New to LC.
I started to put  boarder as frame around the page.
I must be missing something as the results seem unstable.
Or are these bug.
I need exact full scale line within a 1mm at the most.
Seem I cannot upload my pdf's
Here are a couple of examples with comments.
Trial 1
Command: l (line)
Command: l (line)
Direct print, lower line off the paper.
Export to pdf. Both lines on the paper.
On the pdf, using a school ruler
Vertical distance measures 265mm
Horizontal distance measures 190mm
Trial 2
Command: l (line)
0, 100
Line way off the paper in print preview. Same in pdf. Would not direct print.
