Printing Scale Tips...
1 message Options
Jota
If you work with architectural or furniture drawings, I believe this is the best way to work with scale drawings.
Here are some tips:
- First of all, read the User Manual: https://docs.librecad.org/en/latest/about/index.html
- Draw everything in full scale (1:1), even your blocks.
- Learn how to use the Library Browser Dock to insert everything that is standardized.
- Use the scale factor to insert drawings or texts that require printing scale adjustment, such as sheets, title blocks, finish schedules, standart details, etc...
- Whenever you create a new block, make sure that it has been saved with the same measurement units as your default model (see Application Preferences and Drawing Preferences) or this will generate a scale incompatibility with the line weight configuration.
- Adjust the printing scale factor according to the scale defined when inserting the block.
- Watch the workflow demo
Demo.mp4
- For now, that's it...
