Problem creating blocks with hatch
aangelo
Hi all!
I needed to create some blocks with hatch inside, but rectangles (from line>rectangle or polyline) works differently from circles.
LibreCAD version and OS
 Version: 2.1.2
 Compiler: GNU GCC 6.2.0
 Compiled on: Sep 17 2016
 Qt Version: 5.9.5
 Boost Version: 1.62.0
 System: Ubuntu 18.04.2 LTS
test_block_with_hatch.dxf
Steps followed
1. New drawing
2. Application Preferences: Unit: Millimeters
3. Working at Layer 0
4. Circle >Center Point, centered at 0,0 with radius 30
5. Select Circle just created
6. Hatch ansi31, Scale 1
The Circle is correctly hatched.
1. Select the circle and its hatch.
2. Create Block
3. Select 0,0 as insertion point
4. Set Block Name "circle"
5. From Block List, select "circle" then insert the active block.
The new created "circle" is correctly inserted, complete with its hatch.
1. Line >Rectangle, 30x30 units
2. Select the square just created
3. Hatch ansi31, Scale 1
The Rectangle is correctly hatched.
1. Select the rectangle and its hatch.
2. Create Block
3. Select the insertion point
4. Set Block Name "rectangle"
5. The hatch is disappeared
6. From Block List, select "rectangle" then insert the active block.
The new created "rectangle" is inserted, without its hatch.
1. Polyline, insert 3 vertices then Close (from command line)
2. Select the closed polyline
The closed polyline is correctly hatched.
1. Select the closed polyline and its hatch.
2. Create Block
4. Set Block Name "rect_poly"
6. From Block List, select "rect_poly" then insert the active block.
The new created "rect_poly" is inserted, without its hatch.
The same problem occurs with many others hatch styles and is highly reproducible.
I suspect this is a LibreCAD bug.
Someone can help?
Thank you.
Antonio
Re: Problem creating blocks with hatch
jefken
Hi
I have  done what you did
2. Create Block
That's my result
left what I did  and right the result.
I made it in 2.2.0r1
gepensioneerd ingenieur
Gent België
LibreCad 2.2.0 rc1 Windows
aangelo
Hello!
I repeated the procedure, but I still get the same (wrong) result.
Now I'll look if exists a more recent version for Ubuntu 18.04 (possibly the same version 2.2 you tested).
Sent with ProtonMail Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
Il venerdì 12 aprile 2019 15:04, jefken [via LibreCAD] <[hidden email]> ha scritto:
Hi
2. Create Block
That's my result
Gent België
To unsubscribe from Problem creating blocks with hatch, click here.
Antonio
