Quantcast
Problem scaling an image
Blain Albin
Trying to scale an image that I imported.  I'm using the Modify -> Scale command.
The image I've imported is a jpg sized about 3882 x 632 and is 72dpi
I will start the command, select the image, set reference point.
The Scale Options dialog comes up.
I choose Delete Original.
Set scale to 0.5.
Choose Isotropic scaling
Use current attributes is unchecked
Use current layer is unchecked.
When I click Ok my image disappears.  It's like it deletes the original then doesn't redraw the new image.
It works fine if I use it on a normal line object like a square.
Can anyone duplicate this?
Using v2.1.3
Windows 10
Thanks
Re: Problem scaling an image
Yes, I can reproduce this. Funny thing is, I have never realized this before, although I have been playing around with that feature a lot. If you do 'autozoom' the image is back. Perhaps I always did this automatically. It does not react to other zooming or 'redraw', however.
Blain Albin
Thanks for the reply dellus.  And thanks for the work around.  At least I can actually get the intended results.  I was stuck before.
Thanks again.
Loading...
