Problems with hatch when objects are overlapping
nico
Hi and happy new year,
I would like to hatch/fill the surround of two objects. The two objects are partly overlapping. The problem is, that the overlap region is also hatched/filled. Is there a way to fill the surround without filling overlap regions?
Thank you for your help.
Cheers,
Nico
Re: Problems with hatch when objects are overlapping
I feel you have to cut the entities to allow a simple closed contour for hatching.
Here, you may have to cut the circle into 3 arcs, and also, the two intersecting straight lines.
